Bash script for common errors
Hello, I´ve done a little script for common errors on UBports, specially useful for me on sound and modem. I hope you find it useful and improve it, I don´t know how to set the variable ip to the command ssh. I hope they solve soon this errors soon but in the meantime...
It´s on Spanish but:
1) WIFI RESET                          ...
2) ACTIVAR SIM                        Sim
3) ACTIVAR SONIDO                  Sound
4) ACTUALIZAR SISTEMA           System update
 #! / bin / sh
show_menus() {
    echo -e "********************************************** "
    echo -e "** $  1) WIFI RESET                         ** "
    echo -e "** $  2) ACTIVAR SIM                        ** "
    echo -e "** $  3) ACTIVAR SONIDO                     ** "
    echo -e "** $  4) ACTUALIZAR SISTEMA                 ** "
    echo -e "** $  5) SSH                                ** "
    echo -e "Ingrese una opción de menú y ingrese o ingrese para salir. "
    read opt
function option_picked () {
    echo -e
clear
show_menus
while : ;
    do
more
        case $opt in
        1) clear;
        option_picked "Opción 1 escogida";
sudo nmcli radio wifi off
sudo nmcli radio wifi on
sudo poweroff
show_menus;
        2) clear;
            option_picked "Opción 2 escogida";
sudo /usr/share/ofono/scripts/enable-modem
sudo /usr/share/ofono/scripts/online-modem
        show_menus;
        3) clear;
            option_picked "Opción 3 escogida";
modprobe snd_soc_simple_amplifier
modprobe snd_soc_simple_card_utils
amixer -c 0 set 'AIF1 Slot 0 Digital DAC' unmute
amixer sset 'Line Out' 100%;
            show_menus;
        4) clear;
            option_picked "Opción 4 escogida";
sudo apt update && sudo apt upgrade;
           show_menus;
        x) exit;
        \ n) exit;
        *)clear;
        Opción_pulsada "Elija una opción del menú";
        show_menus;
    esac
done
Nice! You made a nice menu I see. I did sort of the same thing: Bash scripts for the basic functions of the PinePhone on GitHub: https://github.com/dirkjanbuter/pinephone-commands (I try to keep it up to date).
(02-10-2020, 08:54 AM)PinePhoneCoder Wrote: Nice! You made a nice menu I see. I did sort of the same thing: Bash scripts for the basic functions of the PinePhone on GitHub: https://github.com/dirkjanbuter/pinephone-commands (I try to keep it up to date).
Have successfully tested several your scripts. Thank you.
However, after a recent update when I turn on the modem with the script, drop the wifi connection. When restore the wifi connection, drop the modem.
Hey, thanks for the script collection. Here's a little suggestion: I made a hidden script in the folder like this:
#!/bin/bash
scriptdir=$HOME/cmd/
cd $scriptdir
ls -1 | nl
echo "Make your choice"
read choice
choicetorun=$(ls -1 | nl -s \: | sed -e 's/^[ \t]*//' | grep ^"$choice"\: | sed -e 's/[0-9]\://' | sed -e 's/^[0-9]//')
./$choicetorun
It makes a list of the folder, like so:
pine:~/pinephone-commands/.la.sh
     1    change-password.sh
     2    ear-on.sh
     3    image-to-internal-storage.sh
     4    install-ffmpeg.sh
     5    install-samba.sh
     6    install-tor-site.sh
     7    killer.sh
     8    mixer.sh
     9    radio-nl-bnr.sh
    10    radio-nl-qmusic.sh
    11    speaker-half.sh
    12    speaker-max.sh
    13    speaker-mute.sh
    14    speaker-on.sh
    15    tor-my-domain.sh
    16    wifi-reset.sh
Make your choice
And you can choose the script you want by number. And if you add a script in the folder, you won't have to modify a file for to have a menu selection.
Nice work. I will test these out.
Just to add to the collection.
I made an install script for UBPorts. Hopefully expand more later.
https://github.com/goddard/pinephone
Anyone played with installing over USB?
#!/bin/bash
cd $scriptdir
ls -1 | nl
read choice
./$choicetorun
     2    ear-on.sh
     4    install-ffmpeg.sh
     5    install-samba.sh
     7    killer.sh
     8    mixer.sh
     9    radio-nl-bnr.sh
    11    speaker-half.sh
    12    speaker-max.sh
    13    speaker-mute.sh
    14    speaker-on.sh
    15    tor-my-domain.sh
    16    wifi-reset.sh
Make your choice
Nice "undo", will try that later.
(02-13-2020, 02:25 PM)Goddard Wrote: Nice work.  I will test these out.
Great!
(02-13-2020, 02:25 PM)Goddard Wrote: Anyone played with installing over USB?
No, but do you have an idea where to start?
Unless I am very much mistaken you have to use FEL mode. And, again unless I am mistaken, the PinePhone has no magic button key sequences to boot into FEL mode (although I am curious about the reset button ...) so you either have to use the special SDcard image or ensure there is no bootable image on both the SDcard and the eMMC.
ps - getting off topic, may warrant a new thread
(02-14-2020, 04:58 AM)dukla2000 Wrote: ps - getting off topic, may warrant a new thread
See https://forum.pine64.org/showthread.php?tid=9161 for the new thread.
