Hello, I´ve done a little script for common errors on UBports, specially useful for me on sound and modem. I hope you find it useful and improve it, I don´t know how to set the variable ip to the command ssh. I hope they solve soon this errors soon but in the meantime...
It´s on Spanish but:
1) WIFI RESET ...
2) ACTIVAR SIM Sim
3) ACTIVAR SONIDO Sound
4) ACTUALIZAR SISTEMA System update
1) WIFI RESET ...
2) ACTIVAR SIM Sim
#! / bin / sh
show_menus() {
echo -e "********************************************** "
echo -e "** $ 1) WIFI RESET ** "
echo -e "** $ 2) ACTIVAR SIM ** "
echo -e "** $ 3) ACTIVAR SONIDO ** "
echo -e "** $ 4) ACTUALIZAR SISTEMA ** "
echo -e "** $ 5) SSH ** "
echo -e "Ingrese una opción de menú y ingrese o ingrese para salir. "
read opt
function option_picked () {
echo -e
clear
show_menus
while : ;
do
more
case $opt in
1) clear;
option_picked "Opción 1 escogida";
sudo nmcli radio wifi off
sudo nmcli radio wifi on
sudo poweroff
show_menus;
2) clear;
option_picked "Opción 2 escogida";
sudo /usr/share/ofono/scripts/enable-modem
sudo /usr/share/ofono/scripts/online-modem
show_menus;
3) clear;
option_picked "Opción 3 escogida";
modprobe snd_soc_simple_amplifier
modprobe snd_soc_simple_card_utils
amixer -c 0 set 'AIF1 Slot 0 Digital DAC' unmute
amixer sset 'Line Out' 100%;
show_menus;
4) clear;
option_picked "Opción 4 escogida";
sudo apt update && sudo apt upgrade;
show_menus;
x) exit;
\ n) exit;
*)clear;
Opción_pulsada "Elija una opción del menú";
show_menus;
esac
done
