Sailfish install problem.
I'm having an install problem too, but mine is different.  I got the install script to work, it runs says it is downloading the files, then asks me for to SD card location (mmcblk0) in my case.  I give it the block name and it begins to run.  It goes through the process and tells me it was successful and that I can install the card in my Pine64 device.  But when I look at the card, it is empty.  I can unmount from my computer, remount it, and it still shows empty.  When I check the output from the install script it says in a couple of places, "mmcblk0p1 doesn't exist and no size was given" and "mmcblk0p2 doesn't exist and no size was given".  What the heck?  I even went so far as to use gParted to format the card, erase all partitions and make it one big partition (14.4 GB) so it has plenty of room to install to.  Can't figure out what's going wrong.
I refuse to tiptoe through life, only to arrive safely at death.
Sailfish install problem. - by pjsf - 02-06-2020, 10:56 PM
RE: Sailfish install problem. - by Prophentes - 02-06-2020, 11:39 PM
RE: Sailfish install problem. - by dukla2000 - 02-07-2020, 02:21 AM
RE: Sailfish install problem. - by pjsf - 02-07-2020, 09:49 PM
RE: Sailfish install problem. - by noeman5 - 02-16-2020, 01:55 AM
RE: Sailfish install problem. - by nationalicon - 02-17-2020, 08:41 PM
RE: Sailfish install problem. - by harvey186 - 02-24-2020, 10:51 AM
RE: Sailfish install problem. - by olyavi - 02-27-2020, 06:53 AM
RE: Sailfish install problem. - by harvey186 - 02-27-2020, 10:58 AM
RE: Sailfish install problem. - by cefre00 - 02-24-2020, 11:24 AM
RE: Sailfish install problem. - by harvey186 - 02-25-2020, 01:34 AM
RE: Sailfish install problem. - by cefre00 - 02-25-2020, 04:39 PM
RE: Sailfish install problem. - by cefre00 - 03-02-2020, 07:36 AM
RE: Sailfish install problem. - by explit - 03-03-2020, 05:02 AM
RE: Sailfish install problem. - by patrickjquinn - 06-29-2020, 06:33 AM
RE: Sailfish install problem. - by afigegoznaet - 07-10-2020, 09:15 AM
  When mobile data works calls don't with Sailfish OS albafrati 0 2,664 06-25-2024, 09:28 AM
Last Post: albafrati
  Sailfish on PinePhone PiSe 4 4,404 06-17-2024, 05:46 AM
Last Post: PiSe
  Pinephone keyboard with Sailfish fn-keys idc 1 3,233 01-28-2023, 11:48 AM
Last Post: idc
  Using Windows 10 to install SailfishOS Kimberley van Buyten 1 3,398 12-05-2022, 10:36 AM
Last Post: Andidoko
  PinePhone versus Sailfish (Sony/Jolla) richieeee 10 17,744 07-10-2021, 04:18 AM
Last Post: acrux
  Lock screen problem? undo 5 9,896 03-03-2020, 05:00 AM
Last Post: explit
  Sailfish web browser linux6730 3 8,390 02-25-2020, 05:42 AM
Last Post: DrYak
  Sailfish still supported? Mangled 4 9,425 02-08-2020, 08:22 PM
Last Post: Mangled
