My first attempt at a wrap
Just a cheap wrap from Amazon and it's my first ever attempt. It is VERY FAR FROM perfect but it's ok. No experience with wrap but I believe it's too thick and not sticky enough to wrap around the edge correctly.. Anyway, if you want to see;
I actually used the Sharpie to darken the edges as it was white when trimmed.
https://imgur.com/4sE8BfQ
https://imgur.com/HjOngaz
https://imgur.com/9Nz3ZoJ
https://imgur.com/Blfb0zd
https://imgur.com/ZqZsrRt
I'll be replacing it when I can find a better wrap material.
I've made vector templates for the lid, palmrest, and bottom available on the wiki. I've been updating them as I update my own templates. You can probably find better vinyl at one of your local sign shops. Look for anywhere offering removable vinyl. If they offer car wraps, you should be good with that, too. If you find a good one, they should be able to be to print and cut for you.
That looks amazing!
Robbie Ferguson // Bald Nerd
NEMS Linux: https://nemslinux.com/ | My TV Show: https://category5.tv/ | My Blog: https://baldnerd.com
