CUPS, 50%
But I'm not using 'buntu so it's probably better than that
Stock, Q4OS (stretch): NO ,,,, manjaro,bullseye: YES
Just to save you some time, if you meet caveats, 5 minutes,
otherwise waste hours, and no result
With an arm device you are almost certain to use airprint (bonjour/avahi)
(unless you have postscript printer or compile filter yourself, manjaro has some)
Background: Apple came out with airprint about 2010 for iphone, ipad
the manufactures quickly adopted because ..... apple
Printer must be 2010 or >
localhost:631 is cups 2.2.4 or >
Printer on network,,,,, there is a driver for ipp/http over usb, you must compile
Then it is just a question of the right address, cups will let you know if wrong
The ppd is a bit sparse, but you get to print
For older, use SAMBA
--edit--
I was not clear, when time to pick ppd, pick generic
1st is ipp everywhere,, ippeve.ppd
2nd is driverless,, drvless.ppd
Slightly different
If you pick specific model, will NOT work
Users browsing this thread:
