FIX: Little or no lcd backlight
Just got my PBP! I love it, it's sleek as hell and a bajillion times lighter than my old HP.
One problem though: it decided to lose its backlight. I could just barely make out the shapes on the screen, but it was far from usable until I started looking around and found an interesting file: /sys/class/backlight/edp-backlight/bl_power
This might not work for you, but it did help me:
echo "0" > /sys/class/backlight/edp-backlight/bl_power
All's well that ends well
UPDATE:
The problem came back after a couple of reboots. I guess having the lcd controller offline for a while might reset it? Anyway, my fix is simple:
open the crontab for root user:
sudo crontab -e
add the following line to the file:
echo "24" > /sys/class/backlight/edp-backlight/brightness
this sets the brightness to 24 (out of 255 because 2^8=256) on every boot. You can replace 24 with any value between 0 and 255 (although I would not recommend 0)
  LCD backlight failing ychemin 1 4,775 02-04-2020, 05:14 AM
Last Post: ychemin
