01-05-2020, 05:15 AM
This is probably obvious but I am not brilliant on linux but how do I enable the 64bit JVM for java? I don't want to just follow some random instructions on the internet due this not been an intel device!
Java 64bit
01-05-2020, 08:07 AM
What OS are you running? The default Debian? I'll probably want to install icedtea. I did it in Manjaro, and it installed fine.
01-05-2020, 10:48 AM
Yes I am running the default at the moment.
Does it have a package already on Debian? or am I looking at doing a source build?
01-05-2020, 11:45 AM
There should already be a package available through apt.
01-05-2020, 12:29 PM
Doh I was lucking for icedtea packages I didn't realise that it produces the open jre and yes there was a package "openjdk-8-jre"
Unfortunately after install running the command "java -d64" still gives "Error: This Java instance does not support a 64-bit JVM."
01-05-2020, 03:07 PM
@Dreamwalker The default Debian is 32-bit only, (aka "armhf"). So, no 64-bit Java.
For me, I want multi-library, 32 & 64-bit userland. A great deal of pre-compiled Linux ARM software is 32-bit, but I'd want 64-bit for OpenZFS & it's kernel modules. Still looking around for my ideal Linux on ARM distro.
Arwen Evenstar Princess of Rivendale
01-06-2020, 04:39 PM
Stupid me it never occured to me it shipped with a 32bit os installed
![]() I was planning to reinstall but still waiting on my nvme adapter before I did it |
| Ubuntu 64bit Bionic for PineBook Pro | futurejones | 3 | 8,256 |
12-17-2019, 04:32 AM Last Post: andybleaden@gmail.com |
