12-03-2019, 05:01 AM
Hi guys,
today I received my Rock64 and of course immediately set it up to do some tests. Openssl now performes way better as visible here:
but openvpn performance is still slower than on Raspberry Pi4:
Rock64
RPI4
As you can see the Raspberry takes 12,76s to perform the test, whereas the Rock64 needs 15,95s. Based on the explanation in this thread
https://airvpn.org/forums/topic/18322-ho...hroughput/
it means, that still the Rock64 is slower. Is openvpn taking advantage of the hardware acceleration of Rock64? Any other explanation?
Thanks!
You have chosen to measure elapsed time instead of user CPU time.
Doing aes-128-cbc for 3s on 16 size blocks: 16712860 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 13207655 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 6899270 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 2457687 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 353153 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 16384 size blocks: 178379 aes-128-cbc's in 3.00s
OpenSSL 1.1.0l 10 Sep 2019
built on: reproducible build, date unspecified
options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr)
compiler: gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/usr/lib/ssl\"" -DENGINESDIR="\"/usr/lib/aarch64-linux-gnu/engines-1.1\""
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes
aes-128-cbc 89135.25k 281763.31k 588737.71k 838890.50k 964343.13k 974187.18k
Rock64
[email protected]:~$ sudo openvpn --genkey --secret /tmp/secret
[email protected]:~$ sudo time openvpn --test-crypto --secret /tmp/secret --verb 0 --tun-mtu 20000 --cipher aes-256-cbc
Tue Dec 3 10:51:06 2019 disabling NCP mode (--ncp-disable) because not in P2MP client or server mode
15.94user 0.00system 0:15.95elapsed 99%CPU (0avgtext+0avgdata 5340maxresident)k
0inputs+0outputs (0major+318minor)pagefaults 0swaps
RPI4
[email protected]:/etc/openvpn $ sudo openvpn --genkey --secret /tmp/secret
[email protected]:/etc/openvpn $ sudo time openvpn --test-crypto --secret /tmp/secret --verb 0 --tun-mtu 20000 --cipher aes-256-cbc
Tue Dec 3 11:52:11 2019 disabling NCP mode (--ncp-disable) because not in P2MP client or server mode
12.69user 0.04system 0:12.76elapsed 99%CPU (0avgtext+0avgdata 5300maxresident)k
0inputs+0outputs (0major+287minor)pagefaults 0swaps
Thanks!
