Quick Hint: Building Electron Apps
Just a quick hint for any individuals building or developing Electron-based apps:
If you simply issue npm install electron, the process will fail with a non-specific 404 error as well as an unhandled promise reject during electron's postinstall stage. This is due to, afaik, the electron downloader pulling for the non-existent arm(maybe?) build instead of the more appropriate armv7l build.
To resolve this, pass the arch flag as such:
$ npm i electron --arch=armv7l or if installing in general: $ npm i --arch=armv7l
Afterwards you should be good to go.
Thanks! Will try to build Rambox app.
Odoslané z ONEPLUS A5010 pomocou Tapatalku
Another hint for any individuals building or developing Electron-based apps: don't. Smile
(11-02-2019, 04:22 AM)aleksei Wrote: Another hint for any individuals building or developing Electron-based apps: don't. Smile
Because? I just need that Rambox app or something like that.
I tried to build Rambox and ended just like on old Pinebook. It looks it was built, but after running it just opens a blank window with menu, without the app contents.
  Possible to run ArmV7 Apps on Manjaro? gandlers 15 22,471 01-22-2022, 05:19 PM
Last Post: gandlers
Question Building custom kernel (5.11.x) for Manjaro? ppafin 4 10,568 06-02-2021, 04:17 AM
Last Post: ppafin
  Building webkit2gtk gleachkr 9 15,313 03-10-2020, 12:17 PM
Last Post: gleachkr
  Gnome3 UI Scaling Hint Jeremiah Cornelius 0 3,005 02-05-2020, 07:10 PM
Last Post: Jeremiah Cornelius
  Quick Question Wayland vs X Jeremiah Cornelius 3 9,313 12-07-2019, 09:00 PM
Last Post: Samarium151
