power connector type please
Can you please tell the rock64 onboard power connector type, part number or link to aliexpress/banggood to order?
The connector on my rock64 seems to be broken - it losts contact periodically. So i need to replace it.
(08-28-2019, 03:44 PM)AlexS Wrote: Can you please tell the rock64 onboard power connector type, part number or link to aliexpress/banggood to order?
Model DC-006 3Pin Black 3.5mm OD/1.35 MM ID Round the needle DC Power Jack Socket Connector.
You can get from following site:
https://www.newegg.com/p/2S7-01KR-03683
https://www.aliexpress.com/item/32706427034.html
I have the same problem with Rock64. The connector loses contact when you move the power wire.  Angry
I have same  issue with oficial power supply bought in Pine64 store. Try first another power supply or change the male connector. It looks like official one is too narrow outer diameter or too wide inner one. I've changed it and everythig works fine now
This connectors works very  well form me. I've done some power cables for my several  rock64
https://www.aliexpress.com/item/32809179414.html
Hope it can helps
(12-22-2022, 10:02 AM)ju0n Wrote: I have same  issue with oficial power supply bought in Pine64 store. Try first another power supply or change the male connector. It looks like official one  is too narrow outer diameter or too wide inner one. I've changed it and everythig works fine now
Hope it can helps
Good and simple idea!
Before doing what you've suggested I've done a measurement with a multimeter, and found it's actually the tip, not the sleeve that loses the electrical contact.
I've started to search for a more complex solution like replacing the barrel connector with a USB-C connector such that I'd power my SBC using USB Power Delivery tech. Seems like quite feasible solution:
  1. Simple way to get 5V at up to 3A (no IC): https://forum.digikey.com/t/simple-way-t...a-15w/7016
  2. Robust way with two IC involved: https://fpx.oxplot.com/
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 957 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 15,688 01-15-2023, 10:36 AM
Last Post: ds00
  Alternative power supply ju0n 0 1,541 09-06-2022, 02:46 AM
Last Post: ju0n
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 5,087 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 3,477 06-23-2019, 05:01 PM
Last Post: Rocklobster
  USB3 enough to power 2,5 external HDD? va88 11 17,369 06-06-2019, 03:40 PM
Last Post: va88
  How to check if my power supply is underperforming? va88 3 5,606 06-02-2019, 05:59 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 7,376 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 3,593 11-26-2018, 11:45 PM
Last Post: evilbunny
  Power Via usb Nelly 2 5,917 02-24-2018, 01:51 AM
Last Post: Nelly
