Powering 4 Hard Drives and Marvell Controller Functionality
Hey all!
I have a question about the rockpro64. It has a pci-e slot which is super cool, and allows me to plug a pci-e raid controller in for a NAS. The one on the website has 2 sata ports, but I'm looking for 4 sata ports, I've read that marvell based cards work well with the rockpro64 and linux.
The SATA power cable in the store works with two hard drives, but how would i power four 2.5" hdds? Could I just splice two of those cables together? Would I have to power them externally?
Has anyone made a 4 HDD NAS with the rockpro64? I'd love some tips.
Thanks!
(04-10-2019, 07:03 PM)epoliqui Wrote: Hey all!
Thanks!
The Marvel 4 SATA ports card works on ROCKPro64. However, the ROCKPro64 power circuit only can carry up to 2 HDD driver due to HDD current consumption. For 4 HDD, it is better to power externally. Unless your 2.5" HDD is power efficient type, you can using the STA power Y split cable as below link. This assumption based on you are using +12V 5A power supply and your 4 HDD combine power consumption less than 20Watt
https://www.amazon.com/Splitter-2xSATA-Y...07Q382DFZ/
Thanks!
Thank you!
Is there a specific distro that's more compatable with the marvell controllers? and are they plug and play?
  Powering a portable HDD JambonLeVrai 3 7,407 04-10-2019, 04:01 PM
Last Post: InsideJob
