PWM on rock64
I want to connect a strip of neopixels to the rock64 for a project.  I plan on using this: https://github.com/jgarff/rpi_ws281x
Physical pin 33 on the pi header is open so I want to use that.  That means I need PWM.  Is that pin able to do that on the rock64 or is that on a different pin?  Do I still need to disable onboard audio or is the a raspberry pi thing?  What DMA channels are available/unused?
If these should really be multiple threads, let me know and I'll break it up.  I didn't want to risk spamming the forums with multiple posts for one issue.
(11-24-2018, 12:06 AM)Mentaluproar Wrote: I want to connect a strip of neopixels to the rock64 for a project.  I plan on using this: https://github.com/jgarff/rpi_ws281x
Working on the same project. Haven't seen anyone get hardware pwm working on the Rock64. See Leapo's library for example of soft pwm, https://forum.pine64.org/showthread.php?tid=5902
Doesn't work fantastically for LEDs though. I've been able to minimize the flicker by performing very slow transitions, and only operating on 1 or 2 channels at a time, but it's still occasionally noticeable.
Video
just tested basic soft pwm using C instead of python. Much better for leds. No noticeable flicker.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,419 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,731 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,458 12-07-2022, 08:22 PM
Last Post: luminosity7
