Slow Samba performances
Hello
I am running Ubuntu18.04.1 LTS on my RockPro64 with the 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 kernel.
I have trouble to make samba running at full speed (I can expect almost 90MB/s) while transfering a file from the board (SD card) to my W10 desktop.
The speed start around 90 MB/s for almost 70% of the file and fall down to 30 MB/s (even less) for the remaining of the file (and for other files as well).
I test with a 2.5 GB file.
When I transfert a file from my QNAP, I run at 100 MB/s.
Does anybody know how to boost samba preformance ? Boost SD card accesses ?
Problem with the SD card ?
Thank you in advance
Ross
I guess the SD card could be the performance bottle neck.
Try with a NVMe SSD, SATA drive, or a good performance USB3 flash drive.
Or if your RP64 has 4GB memory, you can simply use memory based disk.
# mount -t tmpfs none /some/where/
Is your Samba server speaking at least SMB2 protocol?
(I think it chooses terrible SMB1 if you don't tell it otherwise.)
Edit your conf:
[global]
min protocol = SMB2
Then, systemctl restart smbd.service
If you have a suitably good version of Samba you might be able to specify SMB3 but that excludes all pre-Win10 devices and Samba SMB3 support is still limited, ymmv, etc.
  RockPro64 Slow Ping on WiFi jl_678 0 3,412 05-14-2020, 05:08 PM
Last Post: jl_678
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 6,201 04-17-2020, 02:53 AM
Last Post: Thra11
