Marvel 9215 Sata controller support
Could the following sata controller be supported on the rockpro?
http://www.sybausa.com/index.php?route=p...uct_id=722
It has pcie x4 and uses the marvel 9215 chipset.
(09-03-2018, 02:38 PM)MisterA Wrote: Could the following sata controller be supported on the rockpro?
I don't see why not i would check to see if it has arm modules to load into the kernel......
I think it could be made to work. Right now however in get a kernel panic with every pcie card I tested.
Perhaps a kernel recompile will be needed. Not sure what is going on.
I got the following SATA controller card with the Marvell 88SE9230 chipset working: https://www.amazon.de/gp/product/B01ENKQ...UTF8&psc=1
The trick was to put pci=nomsi into the kernel boot parameters in /boot/extlinux/extlinux.conf
(also, before you start looking for driver errors for hours, check if your hard disks are actually working, a defective one cost me n hour of debugging today Big Grin )
(09-24-2018, 04:31 PM)mmatyas Wrote: Hello,
Ok, I will try that.
Until now when I do a coldboot (I plugin the powersupply and then hit the powerbutton) I see the three leds on de pcie card light up, but I get an error message and the system hangs (see picture attached).
error messag PCIe
When I then reset the system (~warmboot) the three leds light up for second and then go out, and the pcie card gets extremely hot. Eventually the system hangs with a kernelpanic again.
Nice job  Smile
Can you please post some benchmarks?
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Adding the switch does not work in my case.
Overall I find the board to be very unstable. Different results after reboots.
1. When I boot with the pcie card inserted: the system hangs during boot.
2. When I reboot: the card doesn't seem to initialise properly (leds poweron but fade out after a second) but the system boots. The card gets extremely hot, 'lspci' doesn't show a thing.
Doing a reboot by pulling the power cable and reinserting it results in situation 2.
Pulling the cable and booting the system once without the PCIe card and then powering it off and inserting the PCIe card, and then do a boot results in the cycle above restarting again.
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,832 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,488 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 3,310 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,522 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,176 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 5,541 11-28-2022, 05:12 PM
  Support for Refresh rates Above 60 publiclewdness 0 2,882 01-01-2022, 11:40 PM
Last Post: publiclewdness
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 47,983 12-13-2021, 11:04 AM
Last Post: Cerberus
  Existings disks and using a StarTech SATA Controller jkugler 1 4,766 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 78,314 10-20-2021, 04:36 AM
Last Post: fieni
