Battery drained while turned off
This problem keeps recurring and I can't even grasp on how I could probably debug it:
 - I am using the Ubuntu Mint image, upgraded to 17.10
 - Installed i3, work in it, still use power manager from Mint
 - I turn off the PineBook with the "poweroff" command
 - I turn it on next day and the battery is dead.
Any clue?
(03-02-2018, 01:11 PM)amentis Wrote: This problem keeps recurring and I can't even grasp on how I could probably debug it:
Any clue?
Just make sure the power LED light turns off before closing the Pinebook lid. This will ensure your Pinebook actually turn off.
(03-02-2018, 01:11 PM)amentis Wrote:  - I turn it on next day and the battery is dead.
Any clue?
I also had to disconnect my optical usb-mouse, because after shutdown and closing the lid the red light from the mouse did shine Sad
(got Q4OS or armbian on my pinebook)
Any clue?
I'm a longtime user, have been seeing some battery power discharge while the machine is off (lid of the chassis can be warm to the touch after hours off). I've yet to get to the bottom of this, but can verify that a machine that's well and truly shutdown can still be discharging.
Got the same problem it's becoming frustrating. Installed q4os hoping that was better, bus same issue. Any clues are welkom
Where did you find Ubuntu Mint? Is is just ayufans Ubuntu with some packages installed or is it a completely different image?
(07-17-2018, 02:27 AM)Wizzard Wrote: Where did you find Ubuntu Mint? Is is just ayufans Ubuntu with some packages installed or is it a completely different image?
I suspect it was a typo, and he meant 'Mate' , since he then mentioned the i3 image. btw, he hasn't been around since March, so you may not get a reply.
  Display battery charge value with LXDE and lxpanel wlad 1 8,129 12-04-2019, 03:36 AM
Last Post: pnts-se
  Improve the life of your Pinebook battery by setting charger's voltage limits wlad 0 4,430 06-11-2019, 02:27 PM
Last Post: wlad
  How can I reliably get battery status on pinebook tillea 5 14,997 06-11-2019, 10:10 AM
Last Post: wlad
  Battery Status in Bionic X-Istence 3 8,479 03-11-2019, 03:52 PM
Last Post: soupbowl
  .bashrc to show battery percentage at prompt e-minguez 1 5,311 03-05-2019, 07:03 PM
Last Post: PatrickM
  Splash But No Login After Low Battery robbiemacg 3 8,087 05-17-2018, 09:30 AM
Last Post: robbiemacg
Information i3wm xenial-i3 introduction -- mate terminal & battery monitor MarkHaysHarris777 4 10,900 08-31-2017, 04:47 AM
Last Post: shirman
