Zwave module on LTS
Any idea if the Z-Wave module for both Pine64+ and LTS are the same? i.e. will the one bought for pine64+ work on LTS?
I currently have xenial-minimal from ayufan-pine64 repositories, ubuntu-mate installed.
I have also installed Openhabian from here (manual steps)
https://docs.openhab.org/installation/op...nual-setup.
Its all up and running.
When I install the z-wave binding and try to get the z-wave serial controller, it says port /dev/ttyS1 or S0 does not exist.
Any idea as to how to get this work?
The same z-wave module was working fine on another Pine64+ board
Sailesh
I don't see any problems with that since the expansion connector pinouts are all the same... maybe the devicetree files are configured differently, but from the hardware side there should be no issues...
Should be same between PINE A64 and PINE A64-LTS
  Connecting the RaspBee ZigBee module to 5V/GND on the Euler bus causes issues karlitos 0 5,042 04-22-2021, 03:05 AM
Last Post: karlitos
  Camera module with Android Kam 4 11,176 11-21-2020, 01:26 AM
Last Post: Little_Johnny
  Camera module with Arch Linux IkerST 0 4,209 05-05-2020, 08:44 PM
Last Post: IkerST
  is it possible to connect 2 Ethernet port to SOPINE module? eddylai 2 8,846 05-03-2017, 12:01 PM
Last Post: bobpaul
  Sopine Module and USB HDMI mbt28 1 6,952 01-23-2017, 08:13 AM
Last Post: MarkHaysHarris777
