UK Power Adapter?
Is the original Pinebook power adapter standard - can I buy a 5V 3A UK adapter from some other vendor as I see that you guys do not provide adapter for UK customers (or if you do please give me the link)...
(11-23-2017, 11:46 AM)dejan Wrote: Is the original Pinebook power adapter standard - can I buy a 5V 3A UK adapter from some other vendor as I see that you guys do not provide adapter for UK customers (or if you do please give me the link)...
I belive that there actually are UK mains inputs available - I'll check and get back to you.
Any news? Smile
Completely forgot, sorry, will write to TL now.
Here is the link for global plugs (UK, US, EU, and AU) 5V 3A power supply: https://www.pine64.org/?product=rock64-5...uk-us-plug
I instead just bought a USB to type-H barrel cable. Can charge / power my Pinebook from any good quality phone charger or Anker battery. Cost a few quid from Amazon.
  pinebook 1080p power/barrel connector/cable cel 0 1,211 08-03-2023, 11:43 AM
Last Post: cel
  Disable auto power on? cel 0 3,169 12-22-2019, 08:41 AM
Last Post: cel
  Add separate power button? maddmike 2 4,548 12-17-2018, 04:35 PM
Last Post: maddmike
  Power supply clarification maldus 5 7,832 12-17-2018, 03:55 AM
Last Post: maldus
  Power LED / Charging LED Question d97 4 6,673 11-21-2018, 10:26 AM
Last Post: Noxmiles
  Internal power connector problem stealthbanana 1 3,887 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
  noise random green pixel when plugged power supply only (solved. see edit.) BatteryDie 5 8,653 09-06-2017, 04:17 PM
Last Post: BatteryDie
Question Power Related Problem Questions p3p1 1 3,285 08-29-2017, 06:06 PM
  Wanted: Better power adapter for Pinebook. flingtoad 4 8,055 08-21-2017, 10:09 PM
Last Post: Siliconserf
Thumbs Down Power Supply Design Flaw Siliconserf 11 16,137 08-15-2017, 12:26 PM
