Dual boot options for ROCK64?
#21
@easyfab thanks for catching that! You are correct. I will fix it now.
awesome and clear write-up a1w.ca. I wonder if it would be possible to have nice syslinux-style GUI for it too.
I tried options such as "menu resolution 800 600", "menu with 80" etc.. none seem to work. It seems it support the nice formatting options of a typical syslinux config.
(01-22-2018, 04:55 AM)a1w.ca Wrote: I tried options such as "menu resolution 800 600", "menu with 80" etc.. none seem to work. It seems it support the nice formatting options of a typical syslinux
Ok, will play with it this week and see if I can, at the very least, insert a background into the menu, etc.
Sorry, I completely messed up my last reply. I meant to say it seems it **doesn't support** the nice formatting options.. but yes you're free to try, hopefully you can figure out something. Thanks!
Ah! no worries. Bit of a pity, but I will give it a go nonetheless.
Is it possible doing a dual boot from ssd & emmc without switching among them?
Anyone have update son this?
I was trying to add multiboot / test out of the box Ayufan's options but couldn't get menu to appear for me but increased timeout increased booting time so it must be out there ...hidden.
(05-01-2018, 03:58 PM)S3phi40T Wrote: Anyone have update son this?
I hope you weren't expecting to see it on your monitor, as AFAIK, it's only visible on the serial console, as it should be way too early in the boot process for HDMI and usb keyboard support...
When I'm connected to the serial console, I see a menu similar to this one discussed back in post 8:
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
891 bytes read in 73 ms (11.7 KiB/s)
Rock64 boot options
1:      kernel-4.14
2:      kernel-4.15-rc6
3:      kernel-4.4
Enter choice: 2
2:      kernel-4.15-rc6
Retrieving file: /boot/Image-4.15-rc6
And there is more info here about the boot menu - https://github.com/ayufan-rock64/linux-b...booting.md
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 180 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,410 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 360 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 663 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 646 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,676 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,609 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 619 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 671 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 648 03-03-2023, 09:24 PM
Last Post: acwest
