Mute speakers when headset is plugged in
Somehow when I plug in a headset sound is played through it but the speakers don't mute and still play sound still.
I like to have the behavior to mute the speakers if I plug in my headphones or headset.
I guess I  need to enable some switch in alsamixer to make it work.
(08-16-2017, 02:25 PM)leszek Wrote: Somehow when I plug in a headset sound is played through it but the speakers don't mute and still play sound still.
Witaj ;Wink
This is a known problem - I believe that anarsoul was looking into it sometime ago. So for now, you will need to manually mute speakers in alsamixer.
Witaj ;Wink
Hi Luke,
In case the issue has not fixed yet, I wrote a simple patch using acpi_listen to automatically mute/unmute when audio jack plugs in/out.
https://github.com/kasramp/PinebookScrip...dphone_fix
Let me know if you have any question.
Witaj ;Wink
Hi Luke,
Very good job! seems to work perfectly. Will make sure to have ayufan see this so it can be included in future images Smile
Thank you, this is very usefull ! Smile
Below it showed that the range for 'headphone volume' is from 0-63, and for ' speaker volume' 0-31.
root@pinebook:/etc/acpi# amixer -c 1 sset 'headphone volume' 35 Simple mixer control 'headphone volume',0  Capabilities: volume volume-joined  Playback channels: Mono  Capture channels: Mono  Limits: 0 - 63  Mono: 35 [56%] root@pinebook:/etc/acpi# amixer -c 1 sset 'speaker volume' 35 Simple mixer control 'speaker volume',0  Capabilities: volume volume-joined  Playback channels: Mono  Capture channels: Mono  Limits: 0 - 31  Mono: 31 [100%]
On my PB I've changed the values as below. Further I had to add the -c 1 option for selecting the right card.
#!/bin/bash case "$1" in    jack/headphone)        case "$3" in            plug)                amixer -c 1 sset 'speaker volume' 0                # amixer -D pulse sset Master 50% not working yet                amixer -c 1 sset 'headphone volume' 35            ;;            unplug)                amixer -c 1 sset 'headphone volume' 0                # amixer -D pulse sset Master 50% not working yet                amixer -c 1 sset 'speaker volume' 31            ;;        esac    ;; esac
p.s. I really recommend to NOT set 'headphone volume' to the maximum of 63, it will probably will be way to loud! (i tried till 51, too loud alread! Wink
