Rock64 second NIC
Is there a way to install a second Gb network interface and making it a POE connection for supplying power to the Pine64 without utilizing a USB port?
This device is too big and a mickey mouse solution.
Looking at the possibility of turning the Pine64 in to maybe a mini PFSense firewall running BSD?
Pete
Auto mator
(08-11-2017, 12:16 PM)petec Wrote: Is there a way to install a second network interface on the Pine64 without utilizing a USB port?
Couldn't you use a USB 3.0 -> GbE dongle ? that would make for pretty quick second networking. As for BSD we'll have to wait and see Smile
edit: something like this
Thank you Luke.
Yes looked here at Amazon for a USB 3.0 NIC and they have an Amazon Basics one for around $13.99 USD.
I was thinking in terms of a larger case for the Rock64 with the two NICs built right in with POE.
For time bean will probably go with the USB 3.0 NIC running Linux instead of BSD.
Just noticed this in the specifications:
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
a 2nd 10/100Mbps Ethernet connection would do fine with POE.
The Rock64 would be running alarm panel management software in Ubuntu.
Just found this...
The RK3328 internal PHY for the 10|100 ethernet link requires additional hardware to function.  While this is obvious to many of our number, it may not be clear to all of you, including me.
The 10|100 ethernet connection requires not only the internal PHY on the RK3328 chip, but also requires what is called a "magjack"  (the RJ45 connector jack)  which includes a fairly sophisticated isolation transformer "inside" the jack housing !  The magjack is relatively inexpensive and may be obtained from various sources;  the Pine store carries a DAC board for the Rock64 which contains a correct magjack, so if you will be using the DAC the magjack tails along for the ride!
Currently (for a while now) been playing with micro travel routers tinker toys running OpenWRT with exposed GPIO ports and such. (LUA works) Not really much to them relating to CPU / working memory though.
The testing microrouter is inside of an alarm panel which provides VPN access to the alarm.  (via wireless, wired or cellular) and communicates to the alarm panel via the NIC or serially via a USB port.
Pete
Auto mator
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 2,012 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 14,502 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 8,781 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 8,425 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 1,346 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 3,910 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 5,268 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 4,207 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 1,646 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 1,717 10-07-2022, 07:50 PM
Last Post: rookie_267
