01-26-2017, 02:54 AM
I just received my Pin64+ (2GB) board and touchscreen and after mounting in the C4 labs case am very pleased.
Also happy to see that I'm not running into the Gb ethernet issue:
Through switch:
As I want to use this for audio (usb out to external dac), one of my main priorities is to keep power line noise (ripple) as low as possible, including on the ethernet and usb ports. I will certainly implement the Pi filter arrangement mentioned in a power supply thread on the forum, but am sure that I have also seen mention of the possibility to add a better 3.3v regulator at the pads here. Unfortunately I've lost the thread where this was discussed. I have a suitable ultra low nopise 5v - 3.3v regulator and would love to try the mod, if anyone can point me to the discussion of how it is done. Obviously the new regulator needs soldering in correctly, but the old regulatory circuit must also be disconnected. Does anyone have any clues/pointers?
BR.
--Marius--
Through switch:
[font=Courier New]Connecting to host 192.168.1.184, port 5201[/font]
[font=Courier New][ 4] local 192.168.1.146 port 33754 connected to 192.168.1.184 port 5201[/font]
[font=Courier New][ ID] Interval Transfer Bandwidth Retr Cwnd[/font]
[font=Courier New][ 4] 0.00-1.00 sec 113 MBytes 947 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 1.00-2.00 sec 111 MBytes 929 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 2.00-3.00 sec 110 MBytes 927 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 3.00-4.01 sec 111 MBytes 928 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 4.01-5.00 sec 110 MBytes 928 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 5.00-6.00 sec 110 MBytes 923 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 6.00-7.00 sec 111 MBytes 931 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 7.00-8.00 sec 110 MBytes 925 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 8.00-9.00 sec 111 MBytes 930 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New][ 4] 9.00-10.00 sec 110 MBytes 926 Mbits/sec 0 1.20 MBytes [/font]
[font=Courier New]- - - - - - - - - - - - - - - - - - - - - - - - -[/font]
[font=Courier New][ ID] Interval Transfer Bandwidth Retr[/font]
[font=Courier New][ 4] 0.00-10.00 sec 1.08 GBytes 929 Mbits/sec 0 sender[/font]
[font=Courier New][ 4] 0.00-10.00 sec 1.08 GBytes 927 Mbits/sec receiver[/font]As I want to use this for audio (usb out to external dac), one of my main priorities is to keep power line noise (ripple) as low as possible, including on the ethernet and usb ports. I will certainly implement the Pi filter arrangement mentioned in a power supply thread on the forum, but am sure that I have also seen mention of the possibility to add a better 3.3v regulator at the pads here. Unfortunately I've lost the thread where this was discussed. I have a suitable ultra low nopise 5v - 3.3v regulator and would love to try the mod, if anyone can point me to the discussion of how it is done. Obviously the new regulator needs soldering in correctly, but the old regulatory circuit must also be disconnected. Does anyone have any clues/pointers?
BR.
--Marius--
