Is the following air mouse supported?
Will the following LG SMART air remote work with the pine?
http://www.lg.com/us/tv-audio-video-acce...gic-remote
Please forgive me, but I'm incredibly ignorant as to how and what is compatible with your IR receiver.
Thanks in advance!
(02-11-2016, 11:09 AM)UrbanGecko Wrote: Will the following LG SMART air remote work with the pine?
Thanks in advance!
I have LG TV and their air mouse, seems like the air mouse solely work with LG TV.
The Magic Remote works like a wireless mouse. It communicates with the TV using RF (radio frequency) at 2.4GHz.
A wireless mouse comes with a USB dongle that you attach to your computer.
For the Magic Remote, this USB dongle functionality is embedded in the TV.
Therefore, it is difficult to capture the RF transmission of the Magic Remote.
It is difficult as in http://samy.pl/keysweeper/
For some TV models, there is a special LG USB dongle that is meant to attach to the LG TV in order to use the (new version?) Magic Remote,
http://www.lg.com/us/tv-audio-video-acce...sb-adapter
Perhaps these new Magic Remotes have additional functionality like a microphone so they need the LG USB dongle.
If you have that LG USB dongle, then it might be detected as a pointing device by Linux.
Connect it to a Linux computer and send back the kernel logs. My Magic Remote is of the old style ;-(.
I would like to know if the Rii Mini i13 Wireless is supported...
(02-12-2016, 10:43 AM)FrenchFrog Wrote: I would like to know if the Rii Mini i13 Wireless is supported...
If it is the one at http://www.amazon.com/Rii-mini-i13-Wirel...B00BQU9NVK
then it comes with a USB dongle. Therefore, both the mouse and keyboard will appear on the Pine64 are standard input devices.
the Mele F10 pro/deluxe remotes, or Minix M1, A2/A2 Lite remotes for that sake should work just fine and are all mouse remotes, i only tested with Mele F10Deluxe, but these remotes are made for android so why shouldn't they work..
-Deco
  Air mouse for Gaming + Kodi pinea64.edison 3 8,336 07-24-2016, 09:20 AM
Last Post: top3b
  Bluetooth Keyboard/mouse? birdcatx7 8 17,112 06-01-2016, 08:56 PM
Last Post: UnixOutlaw
  Air mouse Shown in FruitNinja Video on the kickstarter campaign AlanB 11 23,934 05-03-2016, 08:42 PM
  Aerb Wireless Air Mouse/Keyboard RAGE Sonix 1 4,778 04-29-2016, 05:26 AM
Last Post: pinea64.edison
