Dev toolchain
Can anyone point me to info on setting up the proper dev toolchain for the Pine64? I'm assuming there is a discussion for this somewhere that I'm not able to find. The toolchain and other related dev environment setup so we're all working on the same or similar setups.
Thanks.
-Chad
Not sure if this is helpful (I am not a developer) but here is the link that was given on a similar question a moderator Tllim answered with a link to a bootlog (doesn't seem very helpful to me) https://gist.github.com/apritzel/c92b38b069a645094bf8
It was described as a "Kernel 4.4 boot log that successfully bring up by Sunxi team"
I would also check the pine64 wiki which looks more promising
http://wiki.pine64.org/index.php/Main_Page
Here is the excellent blog posted by Dieter, highly encourage to read if you interest in the Linux bring up.
http://blog.hypriot.com/post/the-pine-a6...un-Docker/
@Dieter, appreciate and thanks on this excellent blog.
Cheers, TL Lim
Thank you!
