4 hours ago
I’ve been a long-time lurker here, mostly following the development of the Star64 and the newer Quartz64 modules. I finally decided to stop sitting on the sidelines and actually start a project that’s been rattling around my brain for a while: building a localized, low-power cluster for testing distributed compilation.
I was recently looking at some of the benchmarks for the newer Quartz64 modules and a specific point that caught my eye was how the RK3566 handles multi-threaded workloads when the thermal envelope is tight. It’s fascinating to see how far we’ve come with these boards, but it’s also highlighting a bit of a "culture shock" I’m experiencing coming from the enterprise side of the industry.
By day, my world is built around absolute overkill. I spend most of my time managing workstations and servers powered by 48-core Xeon processors—specifically the 2.3GHz models with that massive 20GT/s UPI (Ultra Path Interconnect). When you’re used to having that kind of inter-processor bandwidth and nearly 100 threads in a single socket, you get a bit lazy with how you handle resource contention. In that environment, if my code is messy, the hardware usually has enough raw muscle to just brute-force through the overhead.
My personal insight from this hobby so far is that moving to Pine64 hardware is like learning to drive a manual car after years of using an automatic. Suddenly, the efficiency of my thread management actually matters. I’m hitting a wall where my distributed tasks are stalling, not because of the CPU clock speed, but because I’m realizing how much I’ve relied on enterprise-grade interconnects like the 20GT-UPI to handle the data hand-offs between cores. On these SBCs, the "cost" of moving data between nodes or even between cores on the same SoC is so much more apparent.
I’m trying to figure out if anyone else here has made the jump from high-end x86 server architecture to building ARM clusters for serious development work. Specifically, how are you handling the scheduling overhead when you don’t have an enterprise bus to bail you out? I’m starting to observe that my "lean" code isn't nearly as lean as I thought once it's running on a board that doesn't have a massive cache and a high-speed server backbone.
Are we reaching a point where the software stack for these decentralized ARM nodes is actually becoming more sophisticated than what we use on the enterprise side, simply because we have to be so much more mindful of the hardware limitations? I’d love to hear how you guys are optimizing your inter-process communication on these boards.
