60fps display updates possible without GPU?
I finally got the touch screen working! still some spurious events I need to track down still, including an interrupt flood.  But the first thing I added was finger paint mode, to check touch locations, and a button to clear the screen Smile
All good fun, but my 'clear screen' functionality is super slow.  I'm guessing at .25s, slow enough to see the progress.  This is using a framebuffer approach i.e. no GPU, and a memset to do the clear.  But I also tried a direct arm assembly loop, and looks the same.
I dont have enough experience with the PinePhone to know if this is to be expected? or an anomaly in my approach.  I was expecting to be able to easily do 60fps with plenty of spare cycles to run my apps.
So I found a hacky work-around using some double buffering.  I have no idea on performance, but at least I dont see the clear-screen drawing progress now Smile
Update: So I finally got the MMU working on the A53! and my clearScreen performance is now around 42x faster Smile I also found a way to do cycle counting on the chip, and the full screen memset was previously taking 205 million cycles, with the MMU that comes down to 4.8 million cycles. At 24Mhz, I think that equates to .2s, so still not great, but I have no idea what to expect from this SoC...
  Screen seems ok but no display UncleMeat 3 6,132 11-03-2022, 07:02 AM
Last Post: fxc
  Shipping Updates curtisg 0 2,766 07-26-2022, 12:26 PM
Last Post: curtisg
  Order process and updates? dieselnutjob 3 7,725 01-19-2022, 08:36 PM
Last Post: kaida
  Mobian updates for phosh steves 2 6,024 01-17-2022, 02:18 AM
Last Post: bcnaz
  Display dimming unless plugged in Brad 5 9,465 05-09-2021, 01:14 PM
Last Post: Brad
  E-ink display grego 22 44,857 05-09-2021, 11:47 AM
Last Post: ItradedmyN64foraP64
  Pinephone playing 1440p video on external display megous 2 6,885 09-18-2020, 12:57 PM
Last Post: megous
  Flashing display on Community Ed dr.diesel 3 6,702 06-11-2020, 06:07 PM
Last Post: sladew
