* /lib64 is a symbolic link and not pointing at usr/lib64 exactly.
Hi
I see that others have had this issue, but it is not clear to me if there is any solution or bypass ?
Quote:apt upgrade
Preparing to unpack .../base-files_13.8_arm64.deb ...
* The base-files package cannot be installed because
Error: Sub-process /usr/bin/dpkg returned an error code (1)
Best and thanks
/Jan
Upgrade to base-files 13.6 broken by symlink /lib64 -> /usr/lib #99
You can just delete the symlink.
(07-26-2025, 06:25 PM)Dendrocalamus64 Wrote: Upgrade to base-files 13.6 broken by symlink /lib64 -> /usr/lib #99
thanks, it worked for me too
