Modem Issues with the Pinephone
Now part of this was probably my fault, but I'm having some odd issues with the modem.
I got my Pinephone used from a friend, and when I tried to use my SIM card, it could recognize the SIM card was inserted and the towers it could connect to, but it would never be able to connect. So I thought "Okay it's a driver issue" so I went and used the script available at https://github.com/the-modem-distro/pinephone_modem_sdk but I was tired and didn't think to check the current firmware on the modem and that also didn't work. So then I thought to try to load all the old firmwares until it was fully updated, but now the modem still exists and TRIES to function (it'll show me the settings, the lack of bars, and that there's no SIM inserted or that there is inserted) but I can't see it with
lsusb
or
adb
and I'm wondering if it's irrecoverable or not?
I did try connecting the two plates on the back of the board to each other, but perhaps that didn't short them out. When I did that, the modem just disappeared and still didn't exist with any command.
(10-15-2024, 09:19 PM)Temmie19 Wrote: Now part of this was probably my fault, but I'm having some odd issues with the modem.
lsusb
or
adb
When did you get your Pinephone? Pinephone or Pinephone pro?  Newer modem modules firmware can be wonky when upgraded but it is addressed and 100% fixed on themodemdistro's website https://themodemdistro.com/efs_recovery , my PPpro needed this fix.  Don't worry I don't think there is a way to perma-brick your modem in software.  Only in very worst case you will have to short pads to get into emergency flashing mode but I have never had to do that. Are you able to sudo su(be root) and then use fastboot to send the flashing mode command and get firmware to load?  I was able to do it all in software without needing to short the EFS pins. See this thread https://forum.pine64.org/showthread.php?tid=19421 and after you have everything fixed use the instructions on the git to use the latest flashall script and then flash your preferred ADSB.
(edit)
Nothing at all on lsusb? That is a problem, you should either see a Xiaomi Redmi 2 or EC25 depending if it is in normal or fastboot flashing ready mode
Just so you know sudo didn't work for me to get the ADB, fastboot, and maybe flashall script commands to work, you need to sudo su and be actual root then run commands related to this modem stuff.
I suggest everyone read all of the relevant issues https://github.com/the-modem-distro/pine...sdk/issues and pages on the git as well as the website https://themodemdistro.com as the impotant information is scattered, I only found the themodemdistro website and new modem IMEI repair by digging in the issues and seeing it mentioned, it is not mentioned at all in the main git or on most referring websites. The website is great but how are we supposed to know about it?
I hope you enjoy the new(to you) pinephone, it may be a bit underpowered and run through battery but it is a real linux box in your pocket which is a big deal to me no apple, no samsung, no xiaomi, and no google sharing ownership of your phone and privacy.
Quote:When did you get your Pinephone?
A few months ago give or take. I don't know when my friend purchased it.
Quote:Pinephone or Pinephone pro?
I said Pinephone, not Pinephone Pro.
Quote: fastboot to send the flashing mode command and get firmware to load
Unfortunately Fastboot finds no devices either.
Quote:Nothing at all on lsusb?
Nope none at all. There is one slightly different device, but it has no name listed to it.
OK, one trick with the android communication tools is you often HAVE to use root, as in sudo su, and then run commands after becoming proper root, not sudo adb devices etc it has to be real root or at least fastboot wont work and this applies everywhere I have used fastboot and makes little sense to me while still being true.  I am a bit worried about the modem though as it would likely be the older 'good' modem module firmware.
I didn't have to use 'root'.
lsusb gave me several lines, including:
Bus 003 Device 003: ID 2c7c:0125 Quectel EG 25-G
PinePhone Beta 2GB/16GB Postmarket OS v24.12
PineTab2 Arch Danctnix 6.4.2
(07-01-2025, 07:48 AM)gregb49 Wrote: I didn't have to use 'root'.
sudo su is only for adb nad fastboot commands
that(Quectel EG 25-G) is what you want to see when running lsusb internally when serial/ssh'ed into the phone.
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 0 48 Yesterday, 05:08 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 1,048 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone + Keyboard for sale, little use ruemoo 9 2,669 06-10-2025, 09:25 PM
Last Post: skaffi
  Pinephone not booting sd card... bruv 1 678 03-25-2025, 08:51 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 1,501 02-05-2025, 02:30 AM
  Pinephone - broken power button rorus 13 14,350 12-16-2024, 08:32 PM
  various tricks to open the pinephone shengchieh 3 2,361 09-16-2024, 03:42 AM
  my pinephone melted norayr 6 3,497 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 2,280 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  Supported Carrier and Modem Bands NachoMomma 4 3,563 03-23-2024, 02:00 PM
