Uboot says bad image magic - mainline kernel
In an attempt to troubleshoot failing to get generic alpine linux to run on PA64-2G-LTS, I've tried to reduce the problem to the smallest steps that are legible to me.
When booting the kernel, I get "Bad ARM64 Image Magic" I can't figure out what this means, and why it is happening. Sources I have searched seem to be board specific, and found nothing on this board. I've arrived at a point where I cannot find a way to reason further about it, so thus I am reaching out.
I am currently loading the kernel and dtb manually at the uboot prompt:
setenv bootargs loglevel=7 earlyprintk
fatload mmc 0:1 0x42000000 boot/vmlinux
fatload mmc 0:1 0x4a000000 boot/u-boot.dtb
booti 0x42000000 - 0x4a000000
My current configuration is:
        - linux 5.14 from mainline (git:7d2a07b769330c34b4deabeed939325c77a7ec2f)
        - u-boot v2024.10 from https://source.denx.de/u-boot/u-boot (git:f919c3a889f0ec7d63a48b5d0ed064386b0980bd)
        - dtb from the u-boot build
        - bl31.bin from PLAT=sun50i_a64 https://git.trustedfirmware.org/TF-A/tru...ware-a.git lts-v2.10.6 (git:f2aebf361050d69176d60016170291efa9e08a68)
        - scp.bin from https://github.com/crust-firmware/crust 0.6 (git:ffe9f1ac9c675e6e67db9084bd19fbdeffd8e162)
        - u-boot-sunxi-with-spl.bin written to offset 8k
        - tried sd and emmc vfat single partition (whole disk) with
                * boot/vmlinux
                * boot/u-boot.dtb
Files:
    - uboot defconfig: https://g33k.holbrook.no/c36cab0e6a15127...7b25f71bdd
    - uboot environment (saved from soc): https://g33k.holbrook.no/1c4d93e6510eb49...2329468b73
    - linux defconfig: https://g33k.holbrook.no/5bde4487e333f5a...19beb3382f
Sigh, of course I was trying to load the wrong kernel file, vmlinux instead of arch/arm64/boot/Image
Thanks to apritzel@itc:oftc:#linux-sunxi for pointing it out
(10-14-2024, 09:15 AM)lash Wrote: Sigh, of course I was trying to load the wrong kernel file, vmlinux instead of arch/.../Image
Spot your IRC messages with apritzel at Linux-Sunxi chatroom :-)
This was great fun, I reached the first milestone and if it's of interest to anyone I thought I'd share my experience:
Did not see usb stick assigned to sdX, but spotted kmod "uas" depending on usb_storage on my own PC. Thus added CONFIG_USB_UAS=y to config. After that it shows up in pine's kernel.
(Though, when usb stick plugged in at powerup, path for root /dev/mmcblk0p1 does not work anymore, but that can be sorted later).
Statically built bash and used as init (using crosstool-ng, works like a charm):
bash         export CROSS_COMPILE=aarch64-unknown-linux-gnu-         export ARCH=arm64         export PATH=$PATH:/home/lash/x-tools/aarch64-unknown-linux-gnu/bin         ./configure --host aarch64-unknown-linux-gnu --enable-static-link --enable-minimal-config          make CFLAGS="-Wl,-w" -j8
final u-boot command sequence:
        setenv bootargs root=/dev/mmcblk0p1 init=/bin/bash earlycon console=tty debug loglevel=7         fatload mmc 0:1 0x42000000 /boot/Image         fatload mmc 0:1 0x45000000 /boot/u-boot.dtb         booti 0x42000000 - 0x45000000
sdcard tree:
/mnt: bin  boot /mnt/bin: bash /mnt/boot: Image  u-boot.dtb
can't do much with this of course, but from here on it is pretty familiar territory
Ah yes, and still on the 5.14 kernel.
  Kernel rebuild resources and process for pine64-LTS Atreyo tech 2 7,664 07-02-2021, 12:23 AM
Last Post: Atreyo tech
  Networking on A64 LTS broken on Debian with Kernel 5.9 kuleszdl 0 5,225 01-02-2021, 06:26 PM
Last Post: kuleszdl
  Fedora-30 w/ kernel 5.0 maya.b 1 9,394 02-24-2019, 01:48 AM
  Arch Linux mainline XFCE (PINE A64-LTS / SOPINE) pineadmin 1 10,603 11-09-2018, 03:07 AM
Last Post: pineadmin
  No boot on any Linux image :/ oxomoxo 2 6,112 08-11-2017, 09:44 AM
Last Post: oxomoxo
