Can't install some software with pacman anymore
I'm trying to reinstall some stuff after distro hopping and when I try to install firefox, I get the following error.
sudo pacman -S firefox resolving dependencies... warning: cannot resolve "tracker3", a dependency of "gtk3" warning: cannot resolve "gtk3", a dependency of "firefox" :: The following package cannot be upgraded due to unresolvable dependencies:       firefox :: Do you want to skip the above package for this upgrade? [y/N] error: failed to prepare transaction (could not satisfy dependencies) :: unable to satisfy dependency 'tracker3' required by gtk3 :: unable to satisfy dependency 'gtk3' required by firefox
I wasn't getting this error before I tried disro-hopped, and I don't know why I'm getting it now. I checked out http://fl.us.mirror.archlinuxarm.org/aarch64/extra/ to see what was there and while there is a tracker package, it isn't called "tracker3" or even looks like it is versioned that high. A lot of posts I've found when googling suggest tricking pacman into thinking it is installed (I think, I may be misunderstanding), but doesn't explain why this is happening now. I lso don't see any posts about arch in general getting this problem. I've also tried a full sudo pacman -Syyu with a reboot, and still have the same issue.
Is there something I could do to address this or do I just wait for it to sort itself out?
I do have "tracker3" installed in my pinetab2, just checked.
Maybe this is dumb but, have you tried to install it from pacman directly, i mean without having it go through dependencies, maybe it was deleted previously.
If you don't see it maybe you need to refresh your keys, see this post:
https://forum.pine64.org/showthread.php?tid=19309
Hope this helps.
Tracker3 was replaced with tinysparql
I suggest you refresh you databases and do a whole system update
sudo pacman -Syu
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 4,182 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Upgrading/Updating using Pacman Ptab2newb 10 11,725 06-27-2023, 12:17 AM
  What OS and Software Are You Running On Your PineTab? ImmyChan 3 6,423 03-02-2021, 02:51 AM
Last Post: tomoqv
  how do I know which linux OS I can install on a pinetab dln949 20 39,875 09-11-2020, 05:07 AM
