Small battery capacity 3 AH.
Hi.
Why battery have so small capacity?
Is possibly put inside 5 AH?
Thanks for answer.
(08-04-2024, 05:21 AM)Piotr Bujakowski Wrote: Hi.
Thanks for answer.
certain point it boils down to physical size. do we want physically bigger phone with bigger battery. bigger battery as capacity being bigger.
pine org decided to go with ~3000mAh battery, although being replaceable. maybe it is easy to get compatible batteries.
in my view, next pinephone model should have bigger battery, maybe at least 5000 mAh. but it also should be replaceable. so, is there good options.
selected arm cpu's ended up being power hungry, maybe it was not expected to be this power hungry. cpu's being used are intended to be small computers or iot devices.
What is current time on battery?
(08-11-2024, 04:11 PM)Piotr Bujakowski Wrote: What is current time on battery?
In my experience,
1.5 hours for heavy usage (firefox, youtube)
6-8 hours light usage (texting, quick calls)
24+ hours in suspend
To short suspend time.
  At what voltage is the battery fully drained? ethical_haquer 1 2,203 04-03-2025, 03:30 PM
Last Post: Alho
Sad PPP shuts off when reaching battery level >50% <70% crt0mega 6 8,836 04-01-2025, 08:33 AM
Last Post: ethical_haquer
  [Mobian] : Battery consumption and driver/middleware compatibility freelectro 1 3,160 05-30-2023, 03:27 AM
  Custom Battery Design questions. tenzen 1 3,521 04-26-2023, 11:00 PM
  Question on the keyboard battery with phone knoxvilles_joker 0 3,252 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  J7 battery Frost1776 6 10,929 03-09-2022, 03:09 PM
Last Post: tckosvic
Question Battery not charging when run down to 0. iwm 2 4,700 02-08-2022, 10:45 AM
Last Post: mburns
  Battery discharge problem g4mba5 16 21,502 02-01-2022, 03:30 AM
Last Post: bcnaz
