Recent danctnix update/futuresql
I'm updating danctnix on my PT2 for the first time in a while.
pacman -Syu
prompts me as such:
:: Starting full upgrade ...
:: Replace futuresql-qt6 with extra/futuresql? [Y/n]   (took default)
:: futuresql-0.1.1-3 and futuresql-qt5 are in conflict.  Remove futuresql-qt5? [y/N]  (took default)
:: futuresql-0.1.1-3 and futuresql-qt5-0.1.1-2 are in conflict
and that's it.
I suspect the QT6 upgrade has made its way into Danctnix?  Does anyone know which version I need in order to move forward here?  I updated my keys using pacman-keys, so this should be the latest updates.
Also, has danctnix adopted the QT5 -> QT6 transition?   Is it stable?
Thanks.
(07-16-2024, 03:22 AM)zoward Wrote: I'm updating danctnix on my PT2 for the first time in a while.
Did you update your mirror?
https://github.com/dreemurrs-embedded/Pi...issues/598
(07-16-2024, 03:22 AM)zoward Wrote: Also, has danctnix adopted the QT5 -> QT6 transition?   Is it stable?.
He did about 4 month ago. I do not know about stable, I use Phosh
https://github.com/dreemurrs-embedded/Pi...ts/master/
Looks like futuresql-qt5 was dropped, and as a result, futuresql-qt6 renamed to just futuresql. I would just answer "y"(es) to both of those questions. If there is anything on your system still depending on futuresql-qt5. pacman will complain again. Otherwise, there is no point in keeping futuresql-qt5 around, it is a library, only useful if used in an application.
Thumbs Up IMHO, a really NICE update to danctnix yesterday iksar@gmx.com 1 1,689 01-28-2026, 12:40 PM
  Is Danctnix about to get cameras on Pinetab2 biketool 0 1,428 12-11-2025, 06:19 AM
  Danctnix USB GPS for Pinetab2 biketool 0 1,213 11-28-2025, 06:09 AM
  Old Danctnix server in Pacman Config (solved) KelsonV 3 2,323 11-27-2025, 05:01 PM
Last Post: realchunkyflea
  auto-owning the SD card in DanctNIX (Pinetab2) biketool 1 1,742 11-25-2025, 04:16 AM
  Pinetab2s running DanctNIX just got Bluetooth!! biketool 0 1,429 11-02-2025, 04:45 AM
  pinetab2 danctnix broken during upgrade - shell error acruhl 6 13,149 07-23-2025, 06:27 PM
Last Post: acruhl
  How to Donate to DanctNix addictioneer 2 2,881 07-12-2025, 03:53 PM
Last Post: addictioneer
  Pine won't boot after last update Corfromleuven 1 3,562 03-31-2024, 05:21 AM
Last Post: Surehand53
  Updating the "extra" repository breaks the Danctnix OS Evergreen 0 2,648 02-24-2024, 12:40 PM
Last Post: Evergreen
