capabilities of the usb ports
The documentation states that the lower usb port is "USB-C 2.0 + Power Delivery (device mode by default & power input)". Is there a way to put it in host mode and use it as a regular usb port ?
Does it needs a change on the hardware side, the kernel driver (.dts file), a setting file, some command ... ?
The upper usb port is usb3, host mode only. But not all usb3 devices are recognized. Is this the same problem as with the Quartz64 board: "USB 3.0 (applies to Model A only) — only works with very short cables and depends on the device."
Example of device not recognized (hub has usb2, usb3 and ethernet):
dmesg when plugging in VIA 813 USB 3.0 hub + RJ45 Ethernet Adapter: usb 1-1: new high-speed USB device number 2 using xhci-hcd usb 1-1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice= 2.21 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: USB2.0 Hub usb 1-1: Manufacturer: VIA Labs, Inc. hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected usb 1-1.3: new high-speed USB device number 3 using xhci-hcd usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00 usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6 usb 1-1.3: Product: USB 10/100/1000 LAN usb 1-1.3: Manufacturer: Realtek usb 1-1.3: SerialNumber: 000001 r8152 1-1.3:1.0: load rtl8153a-4 v2 02/07/20 successfully r8152 1-1.3:1.0 eth0: v1.12.13 r8152 1-1.3:1.0 enu1u3: renamed from eth0 dmesg when plugging in SanDisk Extreme SSD (SDSSDE60-500G) via hub: usb 1-1.1: new high-speed USB device number 4 using xhci-hcd usb 1-1.1: New USB device found, idVendor=0781, idProduct=558c, bcdDevice=10.12 usb 1-1.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 usb 1-1.1: Product: Extreme SSD usb 1-1.1: Manufacturer: SanDisk usbcore: registered new interface driver usb-storage scsi host0: uas usbcore: registered new interface driver uas
lsusb (partial):
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M     |__ Port 1: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M         |__ Port 1: Dev 7, If 0, Class=Mass Storage, Driver=uas, 480M         |__ Port 3: Dev 6, If 0, Class=Vendor Specific Class, Driver=r8152, 480M Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub   Bus 001 Device 005: ID 2109:2813 VIA Labs, Inc. VL813 Hub     Bus 001 Device 007: ID 0781:558c SanDisk Corp. Extreme Portable SSD     Bus 001 Device 006: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Same devices connected to a Linux Mint laptop:
dmesg when plugging in VIA 813 USB 3.0 hub + RJ45 Ethernet Adapter: usb 2-4: new SuperSpeed USB device number 6 using xhci_hcd usb 2-4: New USB device found, idVendor=2109, idProduct=0813, bcdDevice= 2.21 usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 2-4: Product: USB3.0 Hub             usb 2-4: Manufacturer: VIA Labs, Inc.         hub 2-4:1.0: USB hub found hub 2-4:1.0: 4 ports detected usb 2-4.3: new SuperSpeed USB device number 7 using xhci_hcd usb 2-4.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00 usb 2-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6 usb 2-4.3: Product: USB 10/100/1000 LAN usb 2-4.3: Manufacturer: Realtek usb 2-4.3: SerialNumber: 000001 usb 1-6: new high-speed USB device number 8 using xhci_hcd usb 1-6: New USB device found, idVendor=2109, idProduct=2813, bcdDevice= 2.21 usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-6: Product: USB2.0 Hub             usb 1-6: Manufacturer: VIA Labs, Inc.         hub 1-6:1.0: USB hub found hub 1-6:1.0: 4 ports detected usb 2-4.3: reset SuperSpeed USB device number 7 using xhci_hcd r8152 2-4.3:1.0: load rtl8153a-4 v2 02/07/20 successfully r8152 2-4.3:1.0 eth0: v1.12.13 r8152 2-4.3:1.0 enx00e04c6801f3: renamed from eth0 dmesg when plugging in SanDisk Extreme SSD (SDSSDE60-500G) via hub: usb 2-4.1: new SuperSpeed USB device number 8 using xhci_hcd usb 2-4.1: New USB device found, idVendor=0781, idProduct=558c, bcdDevice=10.12 usb 2-4.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 usb 2-4.1: Product: Extreme SSD usb 2-4.1: Manufacturer: SanDisk
lsusb (partial):
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M     |__ Port 4: Dev 6, If 0, Class=Hub, Driver=hub/4p, 5000M         |__ Port 1: Dev 8, If 0, Class=Mass Storage, Driver=uas, 5000M         |__ Port 3: Dev 7, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M     |__ Port 6: Dev 8, If 0, Class=Hub, Driver=hub/4p, 480M Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub   Bus 002 Device 006: ID 2109:0813 VIA Labs, Inc. VL813 Hub     Bus 002 Device 008: ID 0781:558c SanDisk Corp. Extreme Portable SSD     Bus 002 Device 007: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub   Bus 001 Device 008: ID 2109:2813 VIA Labs, Inc. VL813 Hub
Connecting the usb drive directly to the usb port (without the hub) works as intended:
usb 2-1: new SuperSpeed USB device number 3 using xhci-hcd usb 2-1: New USB device found, idVendor=0781, idProduct=558c, bcdDevice=10.12 usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 usb 2-1: Product: Extreme SSD usb 2-1: Manufacturer: SanDisk /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M     |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub   Bus 002 Device 003: ID 0781:558c SanDisk Corp. Extreme Portable SSD
Same questions as with the lower usb port: is this behavior hardware related, driver related, dependent of a setting, ... ?  Are there usb3 hubs with a RJ45 port which are correctly recognized as usb3 ?  Since (for the moment) we need the usb port to provide a network connection, it would be nice if usb3 is also available using a hub so we can enjoy better speed (x10) for networking and other connected devices as usb disks.
  any chance to use both USB ports in host-mode? lllll 5 6,146 12-21-2023, 09:49 AM
Last Post: dachalife
