Pinetab2 not booting.
Upon arrival my pine tab 2 didn't boot.  So I flashed a SD card and tried booting via the UART adapter. I get the following message when using screen:
mmc1: error -110 whilst initializing mmc card
I've used probably 4 different SD cards.
The screen comes on but nothing displays. Any help would be appreciated. Thanks!
For some reason now I'm not getting any error messages with screen. The display remains blank.
(07-05-2023, 06:30 PM)elix Wrote: Upon arrival my pine tab 2 didn't boot.  So I flashed a SD card and tried booting via the UART adapter. I get the following message when using screen:
I did get that error, or something similar, once, trying to boot from an SD Card, but I did persevere. I tried installing Mobian, in the hope that Mobian had included a WiFi driver, but after installing, and shutting down, I was in the same position as you. Blank screen and no matter what I tried, it would not boot.
I've had more success though, than you, as I wrote danctnix-factory-image-20230527.img.xz to a well used 32gb SD Card, and using the instructions at "using the debug UART adapter" was able to rewrite the "factory image" successfully (no WiFi of course).
I do wonder if the mmc1 error is referring to your eMMC storage rather than the SD Card, as I found the UART adaptor quite tricky to use. You seem to have to switch at just the right moment.
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12)
PineTab2 Arch Danctnix 6.4.2
Yea I'm using that image. Its just really puzzling because now I'm not getting ANY output in screen.
Are either of you able to connect an external display via HDMI?
There are others with a blank screens, but the device is still booting.
No I haven't. This may be a stupid question but what type of HDMI adapter will I need?
(07-07-2023, 04:30 PM)elix Wrote: No I haven't. This may be a stupid question but what type of HDMI adapter will I need?
A micro HDMI to HDMI adapter should do.
Please refer to the wiki: https://wiki.pine64.org/wiki/PineTab2
PinePhone, Pinebook Pro & PineTab2 owner.
I have. Many times.
(07-07-2023, 12:20 PM)Purple_Illusion Wrote: Are either of you able to connect an external display via HDMI?
I thought I had replied to this but cannot see it.
A Pi4 HDMI cable should work as it is a micro HDMI to HDMI cable. [Image: 23y-ptab2-ext-disp.jpg]
However, it didn't work in my case although the PTab2 reported that it was connected to an external display and allowed me to switch between various modes, but nothing appeared on the external screen.
There is a discussion on going at Pinetab 2 screen no longer coming on.
  Castle Game Engine on PineTab2 now officially available michalis 3 4,512 02-24-2026, 04:39 PM
Last Post: michalis
  No updates on pinetab2 arch danctnix? Ingen 8 4,542 10-16-2025, 02:57 AM
Last Post: TcCoy
  Libre Office on Pinetab2? Anonymous1989 1 1,794 08-07-2025, 09:50 PM
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 6,982 05-31-2025, 02:34 PM
Last Post: stevepaesani
  New pinetab2 - can't charge it tmhorne 10 8,936 05-13-2025, 12:42 PM
Last Post: tmhorne
  PInetab2, Limit battery charge to less than 100%? rqkeating 0 2,486 06-30-2024, 08:54 PM
Last Post: rqkeating
  New PineTab2 dRateNWAytORy 2 4,585 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 2,492 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 4,393 02-24-2024, 07:14 PM
Last Post: jkboyd
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 3,517 11-05-2023, 10:20 AM
Last Post: WEF
