Victron Energy on PinePhone Pro
Does anyone know if the app from Victron Energy works on the PinePhone Pro?
Victron makes devices for solar energy and the app connects to their devices and their database of daily statistics.
It is generally safe to assume that Android or iOS apps do not work. Android apps may or may not work under Waydroid, and if they run, their functionality may or may not be limited. But they will not run natively on the system. iOS apps will not run at all.
I see that they have a Linux image.
https://www.victronenergy.com/support-an...s/software
Thank you!
Unfortunately, that AppImage is almost certainly built for x86_64 and will not run on aarch64 (64-bit ARM), at least not without using really slow software CPU emulation.
(04-19-2023, 12:43 AM)Kevin Kofler Wrote: Unfortunately, that AppImage is almost certainly built for x86_64 and will not run on aarch64 (64-bit ARM), at least not without using really slow software CPU emulation.
That is unfortunate, but thank you.
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 396 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,431 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 5,558 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 14,060 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,506 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,720 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 4,608 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,198 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,221 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 2,155 06-26-2025, 11:47 AM
Last Post: zetabeta
