Phosh - Tweaks and Customizing
I have been daily driving a PinePhone with Arch Linux and Phosh for over a year now. I wanted to make a post with my tweaks.
Device: PinePhone 32Gig
OS: Arch Linux Arm with Phosh
Phosh version 0.22 (EDIT: 0.22-0.23)
phosh - scaling
sudo mkdir /etc/phosh/ sudo cp /usr/share/phosh/phoc.ini /etc/phosh/ sudo nano /etc/phosh/phoc.ini # Un comment the DSI-1 output section: [output:DSI-1] scale = 2 # Change scale to desired value (ex: scale = 1.5 means 150%) # Save and reboot
phosh - Mount SD
This should automatically done with portfolio-file-manager
sudo pacman -S portfolio-file-manager
#OLD WAY sudo mkdir /home/SD sudo chmod 777 /home/SD sudo mount /dev/mmcblk0p1 /home/SD/
phosh - squeekboard - Custom Layout
# see https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard
phosh - App filter
OFF gsettings set sm.puri.phosh app-filter-mode '[]' ON gsettings set sm.puri.phosh app-filter-mode '["adaptive"]'
# This can also be done with sudo pacman -S danctnix-tweaks-app-phosh
phosh - Remove the vibrate on button press
#remove all unwanted sections
sudo nano /usr/share/feedbackd/themes/pine64,pinephone.json
phosh - Desktop Icons (edit/add)
# To add desktop icons (synchting) cd /home/alarm/.local/share/applications nano syncthing.desktop #add these lines to syncthing.desktop [Desktop Entry] Name=Synchthing Type=Application Icon=/home/alarm/.local/share/applications/syncthing.svg Exec=firefox --new-window http://localhost:8384/ Categories=Utility;
# To edit desktop icons cd /usr/share/applications sudo nano org.postmarketos.Megapixels.desktop Name=Camera Icon=/home/alarm/.local/share/applications/camera.svg sudo nano pcmanfm.desktop Name=File PCManFM Icon=/home/alarm/.local/share/applications/filecabinet.svg sudo nano axolotl.desktop Icon=/home/alarm/.local/share/applications/axolotl.svg
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 11,657 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  No sms receival on Arch Phosh Pinephone pineuser0 2 4,544 10-09-2022, 08:55 AM
Last Post: treebeard
  Hey Phosh Folks !! Chief 4 6,196 09-06-2022, 12:55 AM
Last Post: Eugo
  Manjaro phosh no screen rotation sandspur 1 3,936 06-23-2022, 01:02 AM
Last Post: rapp
  Phosh - Squeekboard Layout mikehenson 0 3,305 01-21-2022, 10:53 PM
Last Post: mikehenson
  Mobian updates for phosh steves 2 6,064 01-17-2022, 02:18 AM
Last Post: bcnaz
  PmOS Phosh: set compose and change layout stozi 3 5,881 09-24-2021, 07:41 AM
Last Post: ryo
  reduce Phosh bottom bar to corner icon? stozi 0 2,662 08-01-2021, 02:24 PM
Last Post: stozi
  Manjaro Phosh Beta 10...how to get button labels on Angelfish? INSTRUCTIONS WITHIN patrio 4 10,843 06-11-2021, 07:10 AM
Last Post: patrio
  Something that really bugs me in Phosh... mattpenn 1 4,343 02-08-2021, 08:38 PM
Last Post: The3DmaN
