Magnetometer missing
Playing around with the sensors I found out that the magnetometer is missing in /sys/bus/iio/devices, while accelerometer, proximity/light sensor and charger are there.
dmesg tells this:
[  18.550161] iio iio:device0: DRDY on pin INT2 specified, but sensor does not support interrupts [  18.550453] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set [  18.566730] axp20x-adc axp813-adc: DMA mask not set [  18.592344] iio iio:device0: interrupts on the rising edge [  18.598297] gpio gpiochip2: (1c20800.pinctrl): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ [  18.608472] sun50i-a64-pinctrl 1c20800.pinctrl: unable to lock HW IRQ 1 for IRQ [  18.615897] genirq: Failed to request resources for lis3mdl-trigger (irq 135) on irqchip sunxi_pio_edge [  18.625630] iio iio:device0: failed to request trigger IRQ. [  18.640124] st-magn-i2c: probe of 1-001e failed with error -5 [  18.820645] SPI driver st-magn-spi has no spi_device_id for st,lis3mdl-magn [  18.827708] SPI driver st-magn-spi has no spi_device_id for st,lsm303agr-magn [  18.834929] SPI driver st-magn-spi has no spi_device_id for st,lsm9ds1-magn
Seems like the driver could not start. Does anyone have a similar issue?
//edit: Very interesting: If I boot the Pinephone with the Lora Backplane, the magnetometer shows up successfully. Maybe this thread should be moved to the Hardware-Topic
  Nheko - Missing GStreamer plugins videoconvert freelectro 4 6,409 03-04-2023, 11:12 PM
  LibreOffice Fix for tiny menu text and missing title bar grump_fiddle_reinstall 0 2,331 05-29-2022, 11:56 PM
  Self-compiled GTK4: artefacts and missing icons Zombie Feynman 4 7,534 02-06-2022, 05:42 AM
Last Post: Zombie Feynman
  Software update missing on desktop MikeMan 1 3,629 01-27-2022, 06:10 AM
Last Post: bcnaz
  Wi-Fi adapter suddenly gone missing Zebulon Walton 1 3,624 11-15-2021, 05:20 PM
  Is there an encryption package missing from mobian? rp3 0 3,191 01-27-2021, 05:16 AM
Last Post: rp3
