volume button bug
Audio  volume and its indicator on the screen  goes the opposite direction of  the up or down buttons when they are  pressed.   Repeating the button press eventually fixes the problem temporarily until the desired volume is reached.  Do you have this problem?
Volume button problem was hardware. Ordered new one from pine store.
(05-17-2022, 10:07 PM)joshuaperez Wrote: If the volume button is faulty, you have to go to the store to replace it because it is hardware.
You are correct. A replacement switch was  1€. Watched  pinephone disassembly videos to replace.
  troubleshooting sleep/wake button on trixie biketool 5 5,037 05-04-2025, 08:11 PM
  No volume control after latest updates Zebulon Walton 19 22,074 09-08-2023, 08:28 AM
Last Post: jessencan
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 7,548 06-02-2022, 07:16 AM
Last Post: arkadione
  Some apps don't have refresh button lsitongia 3 5,433 09-22-2021, 08:21 AM
Last Post: wibble
  A clear all button for notifications is coming! ragreenburg 0 2,770 08-13-2021, 09:09 AM
Last Post: ragreenburg
  Disabling Volume Rocker? jfenn2199 0 2,381 07-15-2021, 02:25 PM
Last Post: jfenn2199
  Default SMS app send button off screen in vertical orientation motox6 0 2,516 05-22-2021, 02:55 PM
Last Post: motox6
  Dismiss notification button or gesture? vandys 5 9,170 02-15-2021, 07:53 PM
Last Post: pagesix1536
  gnome-contacts not showing call nor sms button cafe 2 5,352 02-11-2021, 01:31 AM
Last Post: cafe
  I just lost Volume up/down bingo600 1 4,161 09-10-2020, 09:39 AM
Last Post: devrtz
