Replacement battery stock in Pine64 store - ETA requested
Since I have a PinePhone on the way, I decided to order the necessary accessories. Several people have advised buying additional batteries to compensate for the relatively shorter battery life compared to the average conventional smart phone.
The Pine64 store indicates that replacement batteries are "Out of stock". Does the Pine team plan to obtain more stock? If so, what is the estimated time that the stock will be available for purchase?
Thanks.
Any Galaxy J7 battery works fine in the Pinephone. I have a couple of these and they work great:
https://www.amazon.com/dp/B07L4GH5B4
(01-25-2022, 01:39 PM)dave_in_common Wrote: Since I have a PinePhone on the way, I decided to order the necessary accessories. Several people have advised buying additional batteries to compensate for the relatively shorter battery life compared to the average conventional smart phone.
Thanks.
I could have missed it, but I do not ever remember seeing the batteries listed as "in stock" when I have looked.
There is a Thread or two discussing replacement batteries,  I Strongly suggest checking those out...
Some batteries fit perfect,  some only need a trim to fit,   some just do not fit.
Ebay has them, I think they range in price from $6 USD to about $12 USD  many are free shipping.
I have purchased two, one was a perfect fit,  one was very tight so I filed one edge lightly to correct the fit.
The forum wiki is good reference, but I think some of their suggested numbers may be in-accurate.
But   IF you decide to purchase extra batteries,
You MAY want the external battery charger adapter that the Pine Store DOES happen to have "IN STOCK"  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Replacement battery for PinePhone? j_s 9 10,707 06-03-2025, 04:19 PM
Last Post: j_s
  Check Battery Level for Keyboard ragreenburg 16 27,821 10-04-2023, 08:54 PM
Last Post: Peter Gamma
  Pinephone KEYBOARD BATTERY ISOLATION. --- 1 3,218 07-10-2023, 04:59 AM
Last Post: mike555
  None Pine64 USB-C Docking Bar? Peter Gamma 0 2,387 03-20-2023, 10:25 AM
  experience: pinephone keyboard drains pp battery faster? tuxcall 2 4,621 02-11-2023, 11:52 PM
Last Post: RTP
  PinePhone Keyboard Review, Documentation, Battery Tools and Custom Layouts Phalio 0 2,645 10-09-2022, 05:09 PM
Last Post: Phalio
  Hardware switch for the PPKB battery? theResonant 3 5,936 07-19-2022, 04:30 AM
Last Post: magdesign
  PSA: The LoRa PinePhone Case seems to drain battery even when shutdown the01player 0 2,657 05-10-2022, 02:32 PM
Last Post: the01player
  PINE64 Response to Keyboard Issues ragreenburg 3 6,003 02-14-2022, 11:55 AM
Last Post: ragreenburg
  PSU for keyboard case battery PD+QC grump_fiddle_reinstall 1 3,888 02-04-2022, 12:56 AM
