Corrupted .img file?
Ok fellas, here's the deal.
I have been unable to get my Pine to start up because I have been unable to mount the OS to my micro SD card.  I have downloaded the file from this location http://www.jide.com/remixos/devices/pinea64 multiple times, and whenever I unzip and attempt to use the packaged .img file and mount it I get the "The disc image file is corrupted" message from the computer.  I have tried multiple copies of the same and different downloads, as well as changing the location, but nothing works.  After that, I tried the PhoenixCard program, but it also gives me errors.  The error I receive from PhoenixCard is "Card preprocess failed !1251"  I have again tried different copies of the .img, but nothing works.  I have formatted the card to EXFAT from my Mac, and repeatedly reformatted, trying to find a solution.  MSDOS was no better, but I only tried it a few times.  The card is a Samsung 64gb EVO+.
Any suggestions or tips?
(06-27-2016, 11:08 PM)NoahJ Wrote: Ok fellas, here's the deal.
Try this image:
http://files.pine64.org/os/remix/remix-v...4-32GB.zip
Burn on your Mac using ApplePi Baker or Etcher. See this thread for details.
(06-27-2016, 11:08 PM)NoahJ Wrote: Any suggestions or tips?
Ghost is on the ball there. Thought I'd just point out you aren't supposed to mount the image file that you download - that image file is the contents of the microSD card - so that's why you use something like the ApplePi Baker tool mentioned on the forum thread mentioned. Hence why it wouldn't open - it isn't a disk image containing a Apple mac program!  Smile
What I noticed that on pine64 is older version of RemixOS, but on the jide it seems that there is newer.
Thanks fellas,
I will get back to you with my next development when it happens. OS is on the card and plugging it in now. I used ApplePi-Baker.
  Remix OS-image for 32gb SD card or way to expand file size? dannyboyswe 2 6,684 05-13-2016, 09:06 PM
Last Post: rahlquist
  help burning the IMG file Moshe.Vazan 5 11,023 05-06-2016, 07:12 AM
Last Post: Moshe.Vazan
