Remix OS-image for 32gb SD card or way to expand file size?
Hi!
Not sure if I've done something wrong when I installed Remix OS on my SD-card, but even though the card is 32gb, there's only like 3gb free space when Remix starts up.
Where is the rest?
Do I need a specific image, or is there a way to expand the file size?
I second this question. I have successfully booted RemixOS on the Pine64 on a 16GB MicroSD card, but I'd like to move the image to a 64GB card and expand the image to use the available space. How do I do this?
I wish to $@#$ they would post clear concise instructions on the wiki about this because this #$@$ is getting old.
For the Android and Remix images. There are two types of image. Phoenix images and regular dd/win32diskimage images.
If you use the Phoenix program and one of its images, it should expand the image to fill 100% of your free space. I have done it with 1GB all the way to 32GB cards.
The dd/win32diskimage images are a fixed size. You download an 8GB image its going to be an 8GB image on any card 8GB or larger. I dont think there is an easy way in android/remix to increase the partition size. The only reason these fixed size images exist is because Phoenix can be temperamental, may not work on a Mac etc.
  sourround sound - Remix MrSarkasmus 0 5,085 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 63,405 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,942 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 248,317 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,479 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,272 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,392 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,568 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,314 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,564 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
