Replacement PCIe slot
Hi
I have the RockProx64  and the PCIe slot has been damaged.  does anyone know if a replacement part is available or the specs of it?
I think it's;s PCIe  x4  36 pin  But not 100% certain.
It's 64 contacts, open-ended. This here should fit: https://www.digikey.com/en/products/deta...TH/6678479 (but it's not open ended)
Desoldering this many pins isn't easy though, so I hope you know what you're in for.
Also this is the ROCK64 forum, not the ROCKPro64 forum.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  Ejection mechanism of microSD slot DOA kuleszdl 2 6,753 09-05-2020, 03:24 PM
Last Post: kuleszdl
  PCIe extender cable for M2 grimace 1 4,278 02-15-2019, 11:15 AM
Last Post: fonix232
  rockpro64 startx hangs system if ssd drive installed in PCIe slot shoupydad 0 2,999 01-24-2019, 07:11 PM
Last Post: shoupydad
Lightbulb micro SD slot (updates) shanewiley 11 22,690 12-03-2017, 11:22 AM
  Warranty, replacement, repair? matwey 2 6,961 12-03-2017, 11:18 AM
