[Solved] My phone won't boot with SD card inserted
Sad
I just got my pinephone yesterday and was very excited to test different distros. The phone can boot from SD card without any issue, but I found that after I flashed the image to eMMC and partitioned my SD card again hoping to use it as storage, my phone just won't boot Sad
The SD card is SandDisk Extreme 128GB SDXC that I bought the same day I received the phone, and I'm sure it's genuine.
The screen lights up after holding power button but it won't even show things like red led that implies something went wrong, it just straight out won't boot.
I've already tried the dd command from
Quote:Reuse SD card for data storage on system booting from eMMC
in the official guide, and I've checked with gparted that all of the spaces of my SD card is formatted as fat32. (I've also tried NTFS)
The phone will boot into the OS I flashed into eMMC if I pull out the SD card.
Any suggestions will be appreciated!
Are you sure you did everything right here:
https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
(11-06-2021, 01:54 PM)acrux Wrote: https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
Thanks for the reply, but I mentioned I did that already in my post Smile
(11-06-2021, 01:54 PM)acrux Wrote: Are you sure you did everything right here:
+1
(you still have boot bits at the front of the SDcard that have to be cleared.)
My bad, found out that I need to use the dd command on /dev/sdb (The SD card) instead of /dev/sdb1 (the fat32 partition I created).
I thought accessing /dev/sdb and /dev/sdb1 will be the same if I create a partition using all the free spaces, but apparently I'm horribly wrong.....
  PinePhone - boot from microSD laserpyramid 7 577 Today, 05:56 AM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 235 04-02-2024, 11:50 AM
  Looking for the "non-phone" OS wakyct 7 1,264 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,066 03-11-2024, 10:42 PM
Last Post: Emelia525
  install iso from sd card to emmc aular 2 326 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 945 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,105 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,793 09-01-2023, 04:26 AM
Last Post: gregb49
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,255 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,788 08-20-2023, 02:44 AM
Last Post: spha
