I am looking to link up Axolotl with my Signal Desktop client and it requires scanning the QR code and copy/pasting the scanned info into Axolotl. Megapixels shows the code but it is hard to make out, does anyone know how I could save the text from that?
07-26-2021, 11:13 PM
(This post was last modified: 07-26-2021, 11:14 PM by godzillest.)
If you tap the square that pops up around the qr code, megapixels gives you the option to copy the url or open it. Unfortunately these buttons don't seem to work at the moment. I had to scan the code with my android and mail it to myself on the pinephone. My desktop signal client is connected. I can't join groups or do voice/video calls from the app. My desktop client doesn't seem to support groups. I haven't tried voice or video with the linked desktop client. Additionally identity verification seems to be dated on axolotl.
Copying the QR code to the clipboard has been fixed in Megapixels 1.0, but as far as I know Mobian is still on 0.16. Before 1.0 the QR-Code was copied to the primary selection (after tapping on the square around the code and selecting "copy") which is not easily accessible in Phosh. You could however connect an external mouse and press the middle button/scroll wheel to paste the code. In any case this only works as long as Megapixels is open. If you close it, the clipboard content from the closed application is lost as is the case with every application in Wayland (unless you use a dedicated clipboard manager).
07-27-2021, 05:35 AM
(This post was last modified: 07-27-2021, 05:36 AM by swiley.)
If you set the display variable vim can read the primary selection (run vim then type "*p)
