What is (or was) "libcanberra"?
Question
Hi, I recently got around to upgrading Manjaro and a couple of update prompts made me curious.
Could someone please tell me what libcanberra-pulse and its successor, extra/libcanberra were for?
It seems after my most recent update, these have been removed.
I'd appreciate any insights into what these were, and what made them obsolete.
Thanks in advance.  Smile
Seems the library had something to do with sound. https://wiki.archlinux.org/title/Libcanberra
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
in the link you provide it says that it plays notification sounds, if you click on "Further description here" you are sent to
http://0pointer.de/lennart/projects/libcanberra/
where the last update was on Tue 25 Sep 2012 and it says that it was ported to GStreamer, that is it was probably incorporated into the GStreamer and there is no separate library any more
(06-30-2021, 09:13 AM)mouffa Wrote: in the link you provide it says that it plays notification sounds, if you click on "Further description here" you are sent to
Thanks Mouffa. That makes sense.
