Can't login after reboot
My battery recently went to zero and the phone shutdown while I was using it.
Now when I reboot the phone, I only see a mouse cursor and the desktop login page.
I can't reboot to the "mobile view".
What should I do? I can connect to SSH.
[Image: VkJXLov.png]
Probably the config for the display manager got corrupted.
You need to reboot from SD and try to fix the autologin section.
In the worst scenario it's some Plasma Mobile file that got corrupted and DM falls back to login screen after unsuccessful start of the environment.
This could happen due to unwritten changes to the disk (not flushed from cache)
Each scenario requires a bit of Linux knowledge to diagnose and fix them.
If you lack time/knowledge the easiest solution is a reflash.
(05-11-2021, 11:48 PM)nightranger73 Wrote: Probably the config for the display manager got corrupted.
Is there any way to "reset" the Plasma Mobile config files? If that doesn't help I will reflash.
  New phone, KDE desktop settings reset on reboot zzb0 2 6,470 10-15-2023, 10:19 PM
  What is the easiest way to login? shengchieh 2 3,644 01-21-2023, 07:08 PM
  Setup/settings lost on reset/reboot GrapeJuice 0 2,540 02-10-2022, 05:40 AM
Last Post: GrapeJuice
  4G disconnect requires reboot cnxsoft 9 13,552 10-10-2021, 04:19 PM
Last Post: prenex
  phosh 11 stops dead at login after update Rainer 2 5,142 07-22-2021, 04:36 AM
Last Post: mouffa
  Mobile Data toggle not retained after reboot Shane 0 2,727 12-23-2020, 07:42 AM
Last Post: Shane
  Reset Password Last Night, Now I can't login Phydoux 6 14,049 11-26-2020, 09:59 AM
Last Post: ak42
  Passcode to login to Manjaro on Pinephone livanti21 4 19,298 10-01-2020, 07:29 AM
Last Post: Doodenheimer
