Flashed my SD card with SXMO Postmarket and now I can't flash other OS's on it
I flashed an SD card with SXMO a few months back and wanted to try a few different OS's now and the issue I am having is when trying to `dd` the new OS (Manjaro with Plasma Mobile) it is giving me an error of not enough space (below) but doing `fdisk` shows me that I have just over 29 GB of space, any ideas why this is happening? It has been a while since I flashed an image on the SD card but I think I followed the instructions properly.
3968401408 bytes (4.0 GB, 3.7 GiB) copied, 65 s, 60.9 MB/s
dd: error writing '/dev/mmcbkl0': No space left on device
60618+0 records in
60617+0 records out
3972612096 bytes (4.0 GB, 3.7 GiB) copied, 65.6348 s, 60.5 MB/s
Output of `fdisk`:
Disk /dev/mmcblk0: 29.1 GiB, 31279022080 bytes, 61091840 sectors
/dev/mmcblk0p1 *      2048  249855  247808  121M 83 Linux
/dev/mmcblk0p2      249856 61091839 60841984  29G 83 Linux
(05-03-2021, 10:53 AM)ragreenburg Wrote: dd: error writing '/dev/mmcbkl0': No space left on device
Is that a typo in the device name?
Shoot, dyslexia strikes again. Thank you for this, I swear I double checked this and didn't see the issue so thank you!
Have you ever successfully written more than 4 GB to that card? If not, then it's possible you have a fake card that was labelled as 32 GB, but in fact only has 4 GB. You could run a test with f3 to verify that.
(05-03-2021, 12:56 PM)kqlnut Wrote: Have you ever successfully written more than 4 GB to that card? If not, then it's possible you have a fake card that was labelled as 32 GB, but in fact only has 4 GB. You could run a test with f3 to verify that.
Thanks for the response, the issue was that I made a spelling error though.
when I used to work at a call centre we used to call this a PEBKAC error.
  PostmarketOS sxmo pinephone keyboard keymaps? afwtioane 2 5,916 09-11-2022, 04:37 AM
Last Post: manubert
  sxmo pim nextcloud Uturn 8 12,851 02-22-2022, 03:23 PM
Last Post: TRS-80
  Battery life on sxmo xark 1 4,105 02-12-2022, 10:07 AM
Last Post: TRS-80
  Official Channels for Sxmo Support anjanmomi 2 6,009 02-12-2022, 09:50 AM
Last Post: TRS-80
  sxmo & php --- 2 4,155 01-31-2022, 01:45 PM
Last Post: ---
  sxmo improvements unrealb2 7 11,572 11-17-2021, 06:43 AM
Last Post: fdlamotte
  SXMO on Debian IVp 0 4,180 08-21-2021, 02:33 PM
Last Post: IVp
  Megi's multiboot sxmo image aithal 1 4,131 06-14-2021, 08:07 AM
  SXMO svkbd with joypad layout [for basic dosbox play] streak 0 2,800 05-27-2021, 08:47 AM
Last Post: streak
  Sxmo on Arch IVp 4 11,003 05-19-2021, 03:18 AM
Last Post: dukla2000
