Rock64 - Reboots after few minutes
Shocked
Hello there,
I have a Rock64 4GB Board, powered by POE and running Ubuntu 18.04.5 LTS (by Ayufan), Booting from microSD, no eMMC installed.
With fresh installations everything works great (i mean bare OS and no other applications), My intention of buying this board is to move away from RPi3B
for my Home Assistant system. I believe Rock64 is much more powerful CPU and extra RAM can provide a better environment.
However after migrating my working Home Assistant from RPi-3B to Rock64, Rock-64 started crashing immediately after boot with kernel panic.
I was able to take a short video to read what's going on with system and below are few lines which hets printed on console at panic.
Note that I have a oversized fan constantly blowing air on Rock64 and Heatsink is also installed on CPU.
Any help to resolve this issue will be appreciated.. Rolleyes  ( I believe this is not too unstable system and can at least handle load what RPi-3B was doing past 2 years)
---- ERROR LOGS ---
INFO: task systems:885 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Kernel panic - not syncing: hung_task: blocked tasks
----  few more lines here with exception stack...
Kernel Offset: disabled
Memory Limit: none
rockchip-thermal ff250000:tsadc: channel 0: temprature(48 C)
THERMAL REGS:
<SOME ADDRESSES IN BINARY>
Rebooting in 10 seconds
(04-22-2021, 08:30 AM)addezai Wrote: Hello there,
---- ERROR LOGS ---
Memory Limit: none
THERMAL REGS:
Sounds like a power issue powering over POE. Try an officially rated power supply.
---- ERROR LOGS ---
Memory Limit: none
THERMAL REGS:
Will try and update...
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,638 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,468 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,722 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,387 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,633 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,101 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,362 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,370 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,770 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,148 11-28-2022, 02:18 PM
Last Post: Macgyver
