No bmp and stepcounter :(
(01-24-2021, 08:58 AM)Martin87 Wrote: Yesterday I installed v 0.11.0.
The heart rate sensor works great! Smile
However the measurement is stopping, when the screen is going off.
It would be great to have a button, that deactivate the power off-mode from the screen. Then it would be possible to have a longer view on the measurement.
Good to hear. Please open an issue on GitHub for any feature requests and maybe include details on how Garmin does it. (https://github.com/JF002/Pinetime/issues)
(01-19-2021, 10:35 AM)danielt Wrote: If anyone is interested in getting the step counter working in Infinitime then I structured the wasp-os driver to make it easy to separate the micropython stuff from everything. Most of the code is C code directly from Bosch anyway so it's much more direct than JF's transliteration of the wasp-os HRS driver. If you're interested then take a look at https://github.com/daniel-thompson/bma42x-upy . You need the generic bma4.c/h code from the BMA423 directory together with bma421.c/h and bma421_config.h from the BMA421 directory (and some callbacks to the Infinitime I2C driver).
PS Once of the videos in my wasp-os series covers both HR and step count: https://youtu.be/lIo2-djNR48
I works on BMA421 pinetime using your driver mentioned above, but when write config file during initialization encounter -5 error
my project :https://gitee.com/fwatch/pinetime/tree/d...421/zephyr
Does reversing the order of the init and the soft reset make any difference?
It seems that IIC driver stuck, not the bma421 driver issue
Is there any reference for bma421 interrupt-driven examples? I can not make it work in interrupt mode(I didn't write config file but I could poll accel data)
https://gitee.com/fwatch/pinetime/blob/d..._trigger.c
