Pogo pins power clarification - reading schematics
#28
Hi All, just wanting to relate my experience on this fascinating but rather complex topic, in the hopes of finding a solution for my needs.
A bit of background - I am wanting to use the PinePhone as a miniaturised version of the Pine A64 LTS SBC with the screen built-in. I have a prototype that looks quite a lot like Project Anakin floating around :-)
There is an RS232 USB device (a sensor) which I connect to the PinePhone USB-C with a USB-A adapter. I'd like to be able to charge the phone via the pogo pins (DCIN/GND) while also powering and reading from the USB sensor. I could do this on the A64 LTS no issue (via DCIN barrel). Mobian is the operating system on the PinePhone, Armbian on the A64 LTS.
On the PinePhone:
* Before attaching the USB device, I found that I could charge via DCIN. Good.
* I then attached the USB device without supplying power to DCIN. USB device worked fine. Good.
* I then supplied +5V to DCIN. Good new? No magic smoke! Bad news? No charging.
* For completeness, I disconnected the USB device and supplied power to DCIN - charging OK.
* While charging I connected the USB device - device would not come up (/dev/ttyUSB*). I have to disconnect the power to DCIN to get the USB device to register.
Another side effect is that the device will not stay off with DCIN powered - no charging while switched off, it keeps booting up again :-(
I'd love if there was a magic way to charge the phone via a pogo pin (ie USB-5V) as debated here, perhaps with USB driver / kernel trickery. My fall-back position right now is to wait for the keyboard/battery to come out and borrow their strategy, assuming they can charge the phone and host a USB device at the same time. Fingers crossed!
Questions:
 * Has anyone tried this on KDE/Manjaro or other distro with better results?
 * Any chances some USB driver / kernel trickery could fix my problems?
Other comments:
 * The wiki should really be updated! At very least I suggest a link to this discussion, mostly to help people avoid possibly costly mistakes.
 * On the A64 LTS (same AXP803 PMIC), the USB +5V rail gets battery voltage when the board is powered down - which sucked, I had to devise a high-side MOSFET switch to work around it. High-side because the screen I was using provided a ground route to all USB devices...ugh
RE: Pogo pins power clarification - reading schematics - by GregH - 03-01-2021, 12:24 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 542 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,261 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,531 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 4,663 06-22-2022, 06:04 PM
Last Post: albafrati
  pine64 keyboard pogo 'no-go' pins --- 3 2,527 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  what are these pins above modem chip? zetabeta 1 1,614 12-13-2021, 04:38 AM
Last Post: kqlnut
  Power consumption during the call some_pinephone_user 0 1,151 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  on off power button stopped working dcinoz 3 2,577 09-01-2021, 03:26 AM
Last Post: dcinoz
  Won't boot until connected to power after sudden power loss brb78 1 1,734 08-30-2021, 12:41 AM
Last Post: bcnaz
  Regarding USB Power and Modem Initialization vidual 2 2,735 08-26-2021, 11:48 PM
Last Post: vidual
