No X Unable to close apps, date/time, new apps
After today's update
Continued Issues
Settings: date/time issue continues - now you cant change the date/time from Jan 10, 2116 20:34
Lolly Pop:head phone issue continues - still doesnt play through the head phone but through the speakers
Software: continues not to display available software and it was not aware of today's update until sudo pacman -Syyu was ran
New issue
Global issue:The X in an minimized app upper right hand corner is missing and there is no intuitive way close an opened app
New app
Disks: - displays partition info although it report SD 32GB and I dont have one present (Maybe I am reading it wrong)
Image Viewer: First impression is it that is working a little more "smoother"
Still well done and I am looking forward to contribute one day!!
(11-24-2020, 11:04 AM)nbh Wrote: New issue
This is actually not an "issue", but an improvement.
The "x"  button for closing apps is no longer there - but, try to to swipe up the open app that you wish to close, put and hold your finger over the app window (in the the same screen where you used to press on "x") and swipe it upwards, the desired app should be closed, isn't that smooth? :-)
Full information about the new beta3 manjaro-arm for PinePhone release can be found here:
https://forum.manjaro.org/t/manjaro-arm-...hone/39446
Hope I have helped a bit
Thanks for the  close app how to and the URL!!
(11-24-2020, 11:04 AM)nbh Wrote: After today's update
Continued Issues
New issue
New app
In terminal  sudo date -s "24 NOV 2020 19:21"  might have fixed it because the entire date time config in SETTINGS has changed including to use the network to set the time.  The change lasted through one power off/on.
Apps are now closed by swiping up instead of pressing the now gone X.
  Unable to hear caller or speak after answering a call danimations 5 9,000 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  SMS apps in manjaro-plasma leave much room for improvement tckosvic 8 14,224 11-15-2021, 03:35 PM
Last Post: tckosvic
  After update black screen and unable to boot anything vmataixf 1 4,314 06-01-2021, 05:32 AM
Last Post: dcinoz
  How to close app when using dock/mouse/keyboard/ext display? alx27 0 2,676 05-27-2021, 06:09 AM
Last Post: alx27
  Ensure Up To Date - Manjaro Plasma Discover Package Manager Sources Linux2thabone 0 2,894 05-05-2021, 11:15 AM
Last Post: Linux2thabone
  Unable to browse network in nemo jborsits 0 2,457 04-19-2021, 10:54 PM
Last Post: jborsits
Brick Bricked phone uninstalling apps. ?? ?? mannipini 2 5,038 12-08-2020, 12:41 PM
Last Post: wibble
  About desktop apps ryo 1 4,226 11-25-2020, 05:39 AM
Last Post: ryo
Question How Do I Close Dialogs and Menus??? acid andy 8 17,912 11-14-2020, 07:01 PM
Last Post: acid andy
  Bluetooth sometimes disappear after a long time sleep. Kawayuppie 1 4,319 10-15-2020, 11:34 PM
Last Post: Veraendert
